Old 07-30-2022, 06:24 PM
MO Olds MO Olds is offline
Default Oldsmobile 455 HD Build
Hi - I have just joined this site after not much luck on TA Country (it had crashed a couple times and all content has been lost lately). I have read a ton of posts on swapping an Olds 455 in place of the 403 on this site prior to joining but have some questions still. I also wanted to start a build thread for my '79 TA as this is an OLDSMOBILE 455 and not a Pontiac...maybe its a Heavy Duty instead of Super Duty!
First, is anyone still around that performed this in the past? Sadly, some of the people i emailed are no longer with us. If so, any pictures available? My main concern is the A/C box. Consensus is that 50% say no modifications and 50% say you need too. Thought a picture would help. The notched valve cover from a Cutlass/442 may be a good option.
Here is summary plan so far:
- Use 403 motor and block mounts
- Use the 455 alternator bracket instead of 403
- Use the 403 Power Steering bracket instead of 455
- If using headers, ones for a '73 - '77 Cutlass with the 455 are most compatible to the TA frame.
- Do not use tall valve covers
- Oldsmobile has 3 different water pump lengths; use the water pump for a 403 onto the 455 or at least one the same length as a 403
Ancient posts that I've been using for some info:
http://forums.maxperformanceinc.com/...13#post2409313
and
https://forums.maxperformanceinc.com...d.php?t=396696
Old 07-30-2022, 06:27 PM
The motor is lone gone hence the 455 but here is a pic of the TA from a long time ago. Shaker clearance issues will not be a problem with the giant hole in the hood!
Name:	Hot Rod Mag.jpg
Old 07-30-2022, 09:39 PM
Trevor78 Trevor78 is offline
Water pump will depend on the combination of brackets and pulleys. 403 brackets generally won't work, or other SBO as they use both head and intake or head and water pump plate to mount.
Old 08-03-2022, 11:03 AM
Thank you.I should have said make sure water pump length is same; the longer version for the 455 and 403 if you have A/C since part numbers are interchangeable.
I've spent a lot of time at ClassicOldsmobile forum for great Olds info but they are light on Trans Am knowledge. I know later on there is issues with factory A/C brackets bolting to Edelbrock performer intake but that will come later.
Old 08-03-2022, 09:04 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Did the 455 Olds install on a one year old 1980 TA. Had no a/c box clearance problem. Used the 403 engine mounts to bolt it in. Engine was from 73 Toronado complete with a/c compressor. Headers were from 70 442 but needed some mods. One pipe was close to the floor at the gas pedel and use to get a little warm on the heel. The car was a turbo 301 that had a fire. Modified the hood into a cowl induction. The shop that got the car after me found a hood and shaker that fit well. The intake was the original Toronado low rize. They also got the a/c working with the Toro compressor.
Old 08-03-2022, 09:36 PM
Big Bear I can't believe it. You would think people are still around or would be able to find at least a picture of the 455 swap but the internet has lost so much of the history. You are the only person I've encountered on the entire web in over a year. Very much appreciate you providing input and experience! Also extremely happy to hear the AC suitcase/box won't be an issue. I may opt for notched valve covers to help but was dreading cutting into the case itself for room as I've read to believe. Nothing like first hand experience!
Old 08-03-2022, 10:45 PM
I've saved several pics of 455 Olds swaps but they don't show much, or the info or fit since many forum threads have disappeared. Still more chance than finding a week old post on fbook. 265/350/403 Olds in Firebird only used the long WP, AC or not, they changed pulleys instead. The extra length allowed more combinations of accessories and smog, without changing individual engines each time.
Old 08-11-2022, 12:06 AM
Thanks for the clarification! I have seen some in the G body forum, I know different model but same years, with a 455 swap and showed some good pics.
Old 08-11-2022, 12:11 AM
I think the battery and speakers are shot but definitely cool! Hope to post engine pics soon when the rebuild is complete as well as installation. Big thanks to Grand73Am for helping with engine paint choices!
ID:	596228   Click image for larger version
Old 08-11-2022, 05:19 AM
What are the engine paint choices?
Of course my previous post should say 260, not 265, wrong obscure engine!
Old 08-11-2022, 09:48 AM
Ha. Somehow I read 260 anyway...
Going with GM Corporate Blue. However, the official PPG code is 15159 but may go with code 16513 which is a little greener and was color matched to a set of 403 valve covers of the time period. I plan to bring those codes to the paint mixers and see which one I like best side by side.
Old 08-11-2022, 09:52 AM
No worries, be aware that they generally go greenish with heat discoloration so an already greenish blue may end up more than intended after some time. A few guys have used Chrysler green as a decent match for 45yr old GM Corporate blue, and it was. But then it discolours...
Old 08-11-2022, 10:52 PM
8453johng 8453johng is offline
That original battery is worth some money. Very rare to see working or not (probably not).
I have a battery topper identical to your original battery over a Walmart battery on my 80 TA pace car.
Very cool do not trash the battery you never see the original battery ever.
Old 08-11-2022, 11:03 PM
Really....steak dinner money or White Castle type of money? ha. Maybe I will drain it and use it for display. I haven't had a chance to throw on a volt meter (99% sure no charge) but might be interesting to see!
Old 08-22-2022, 08:03 AM
77 TRASHCAN's Avatar
I have no info to offer. But have encouragement for you to pull this off. I've often wondered if the combo could be made to work. A 455 Buick would be another cool build!!!
Shut it off
Shut it off
Old 08-22-2022, 08:18 AM
Both have been done, the Olds many, many times. There was a candy apple red 455 Buick swap that featured heavily online years ago.
Old 08-26-2022, 03:23 AM
Keep us updated, thanks for sharing!!!
Shut it off
Shut it off
Old 09-26-2022, 05:38 PM
Thanks for the interest!
Old 09-26-2022, 05:50 PM
Made lots of engine progress...The picture is of the Olds 455 painted in "GM Corporate Blue" which was a custom color match based off research and forum info. I did find a PPG store that could make PPG 15159 into a pint but was >$75. Have some vacation time coming up and hope to have engine installation pictures before end of the year.
The Olds 455 build is pretty stock. Only major changes are:
-Speed Pro SLP-L2323 pistons that will give about 9:1 compression
-COMP Cams 42-229-4 High Energy camshaft that's ground to use with stock components.
-Edelbrock 2151 aluminum intake
-Thorton 6.25 QT oil pan
- Aluminum heavy duty water pump
I figured there was no need to go crazy with the build in comparison to what the 403 originally cranked out!
Old 09-26-2022, 07:59 PM
Jay S's Avatar
Jay S Jay S is offline
Looking good.
I didn’t see what heads you have on your olds, or what year 455 you started with. We have 5 Olds 455 powered cars. One 76, 3 1970’s, and a 1969. One 70 is in our 71 Chevelle. The accessories should not be too difficult to come up with, I have seen that swap in Firebirds before. It didn’t appear to be too difficult of a swap.
With the 268 cam and 9:1 compression it is likely be going to diesel/run-on when you shut the ignition off. Your probably going to need a shut off solenoid keyed to power, you can get around it if you run 93 octane. Olds have 1.6 rockers, it will likely start to float the valves at 4600 rpm with the 268 cam and the stock valve springs. It will be done before that though.
With an aluminum intake on a 455 Olds they are only 70 lbs heavier than a SBC. They are surprisingly light, quite a bit lighter than a 455 Pontiac. The long runners on the intake produce a ton of torque, and cylinder fill thru the low RPM’s. Make sure you run cold enough spark plugs or it won’t be happy.
Olds engines are some of the most oil leak free engine platforms I have been around. Should be a fun dependable combo.
Thread Tools
Display Modes
