Old 11-01-2022, 09:12 PM
Default Convertible owners
I'm curious if when you lower your top, does it drop a bit once it gets over the top (vertical) and laying down? Mine is not smooth when it gets to that point, as it has no tension to keep it from doing this. Is this normal? It makes a bit of a creak sound at the same time.
Old 11-05-2022, 09:04 PM
Jimbobeast Jimbobeast is offline
Normal. Enjoy the open road. Nothing like a rag top.
The Following User Says Thank You to Jimbobeast For This Useful Post:
Old 11-06-2022, 12:47 PM
Thank you. That's comforting to know. I plan on putting my own new top on in the spring and wanted to make sure I didn't need to replace something else while apart.
Old 11-27-2022, 08:36 PM
F ROCK's Avatar
F ROCK F ROCK is offline
I wish i had a convertible!
Back in the '80's; you'd see many 'verts on the road as daily drivers, in the fall/winter, with the top up.
I like the look of most convertibles with the top up; But some look better than others.
I'd always thought the '69 Cougar 'vert looked awesome with the top up.
Along with that, I think the 68-72 Lemans and GTO are some of the best Looking cars with the top up.
I know the magic is cruising w/ the top down, but i also love the look top up.
Just sayin
Old 12-04-2022, 03:23 PM
70oldgoat 70oldgoat is offline
Mine momentarily "catches" at the "peak" halfway when lowering the top.
Does not hesitate when raising the top.
Great looking cars.
"Living our dream, shifting a 4 speed 1970 GTO down life's highway."
70 GTO HT, Original Owner, Atoll Blue, #s Match, 400, 4-Speed, A/C, Hot Rod Power Tour Long Hauler
70 GTO HT, Burgundy, Not #s Match, 455, 4-Speed, Hot Rod Power Tour Long Hauler
70 GTO Convertible, Granada Gold, #s Match, 400, 3-Speed MT, Floor Shift, Hot Rod Power Tour Long Hauler
Old 12-05-2022, 12:57 PM
north north is online now
That delay type thing going up is due to air in the lines. The more air you have the more it will do it, won't hurt anything within reason but if it gets worse you may have a leak somewhere. Too much air in the lines will make life hard on the pump motor and you might end up with a mess under the back seat.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 12-05-2022, 08:56 PM
Thanks. When I replace my top in the spring, I'll probably flush the cylinder out and fill with new. Maybe that will help. I also notice when I first try to activate lowering the top, it struggles to lift off the windshield top. I push up on it a bit and it helps.
Old 12-05-2022, 09:22 PM
That is another sign of excess air in the lines. If you go through the system it’s a good idea to check for leaks and also to separate the reservoir from the rest of the pump and clean out the sludge build up in there. There is a company in California (convertible services I think it’s called) that sells a handy bleeding jug system along with and seals, lines and cylinders etc.
1969 Bonnie Cvt
Old 12-20-2022, 03:57 PM
MJZ's Avatar
MJZ MJZ is offline
I've never noticed anything unusual when mine is in operation. But then again, I can't remember ever paying attention to it because that is when I'm normally connecting my IPhone to blutooth.
