Old 11-20-2022, 10:11 PM
rkraczek's Avatar
rkraczek rkraczek is offline
Default Wanted: 68-72 A-Pillar weather channel
I need a weather channel for a 68-72 GTO/Lemans convertible with a good window guide, as mine is broken, which makes closing the door with the window up a real pain.
Nor sure if hard tops are the same length, but PM me and we can figure that out. I’m also open to buying one in poor condition just for a good window guide. It will be more work for me to drill and rivet, but I’ll take what I can get.
Photos attached for reference
ID:	602396   Click image for larger version
Old 11-20-2022, 11:58 PM
Scott Thelander's Avatar
Default Weather strip l
I have a nice pair off a 69 ragtop with good window blow in tabs
Hardtops are a bit different
And 68 doesn’t have the tabs because of the wing window frame
Scott
2o6-4six5-9165
Old 11-20-2022, 11:59 PM
This is the only pictures I have tonite
I can take others tomorrow
Scott
Old 11-21-2022, 04:07 PM
Default Pillar post seal
I have a pillar post seal from my 72 Lemans in great shape if that helps at all. I bought a new set, since I needed the passenger side.
ID:	602414   Click image for larger version
ID:	602415   Click image for larger version
Old 11-27-2022, 05:21 PM
rkraczek's Avatar
Thanks for all the replies. I ended up buying a set of blow out clips for a 67-69 Firebird/Camaro and the longer ones are a perfect match. A few minutes getting the old rivets out, put the new clip in with rivets, and it looks like new.
Old 11-27-2022, 05:52 PM
NICE!!!
67 Firebird too eh??
Did you get the Ames ones???
