Old 12-07-2007, 10:58 PM
mmarx mmarx is offline
Default '69 GP, what gear?
'69 GP, 400, auto, no AC, what would the rear gear be?
TIA,
Mike
Old 12-07-2007, 11:28 PM
TIA,
Mike
My '69 GP 400 Model J with auto and A/C had 3.23 gears. If the GP follows the GTO with gear selection, then I'd say 3.55s for the non-A/C cars.
To verify jack up one rear tire off the ground. Then get under (be careful, use jackstands/wood blocks front and back to block the tires so the car can't roll!) and spin the driveshaft with the trans in neutral. Count the number of driveshaft turns that it takes to make the wheel go 'round exactly two times.
If you get a hair more than 3-1/2 turns of the shaft, you've got 3.55s.
The above method works for open rears, for a posi rear get both tires off the ground and count the turns of the shaft for exactly one tire revolution.
Old 12-12-2007, 03:29 AM
greyno3's Avatar
greyno3 greyno3 is offline
It's probably a 3.23.....or? You'll find the build sheet on top of the gas tank. Drop it and reach on top.. "BE CAREFULL". The parts car I have like yours had a 3.23 non-posi.
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
Old 12-12-2007, 03:33 AM
greyno3's Avatar
Still love that avatar b-man!!! I would never get tired walkin backwards! Can you imagine her hoppin into your Pontiac and her brains are what's shaken?
Old 12-21-2007, 09:55 PM
limejudge69's Avatar
You can also pull the rear cover and get the numbers off the ring gear and divide them into one another to get the exact gear ratio.
Old 10-28-2009, 07:27 AM
BigKev's Avatar
BigKev BigKev is offline
Hi, Does anybody know what gears I would have if my tailshaft turned a hair passed three turns, would that be 3.23.
Thanks.
Kev
Old 10-28-2009, 08:14 AM
69lm69gp's Avatar
69lm69gp 69lm69gp is offline
Sounds like you have 3.08's. That's what my 69 400/TH400/AC has.
You lost me at LS.
Old 10-28-2009, 08:27 AM
dedsleds's Avatar
dedsleds dedsleds is offline
Thanks.
Kev
3.08
1959 catalina 4dr a/c car
1970 gp strip car ...
1972 gp j 455/4
1971 bonneville hearse 455/4
1972 grand safari wagon 6 pass 455/4
1995 Firebird Formula 5.7 convertible
2002 gp 40th anniv. SC V6
2003 gmc sierra 2500hd 8.1 liter
***LIKE MY FACEBOOK PAGE https://www.facebook.com/GratefulParts***
http://stores.shop.ebay.com/GRATEFUL...__W0QQ_armrsZ1
Old 10-28-2009, 05:35 PM
BigKev's Avatar
Thanks Guys.
Old 10-29-2009, 08:29 AM
Ron Landis's Avatar
Wink Yup...
at @ three and a quarter you'd have your 3.23s. Ron
Old 11-06-2009, 07:28 PM
GPCONV's Avatar
GPCONV GPCONV is offline
Talking
I love my 323's... has a nice tone at highway speeds, yet the low end to get her up and going quick. Gotta find a posi though.
Old 11-06-2009, 08:33 PM
KO KO is offline
From the FSM: 2.93 standard 3.23 peformance 3.55 special order 400 M40 No A/C
1989 Automotive Hall of Fame Inductee
Old 01-25-2010, 12:12 PM
Buckle's Avatar
Buckle Buckle is offline
That's really the only way to know for sure what you have.
I'm here for the TORQUE
