Those units are for full-size B bodies, they are different left to right because of the shape of the cowl design of the B body
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
If anyone has pics of the stamped steel brackets on '69/70 A-body power flow motors, would love to view them.
Here are the dimple locations on a 69 A body, left then right. The spacing looks identical to your set.
Oh sure, anybody could install the correct year/model fans. My way takes imagination!
Much more fun making pieces fit. Oh well... |
Arrrggghhhh!
I was carefully fitting my dash when the Power Flow Ventilation switch disintegrated. After only 50 years! By any remote chance does anyone out there have an extra switch I can beg, buy or steal? It's a rare option in the first place. I'm going to try to fix it somehow... Nobody reproduces these, right? Thanks, Jim |
Here are pics of the broken switch. The black plastic crumbled.
Just thinking out of the box but maybe you can use a rear defogger/antenna/rear window switch. Remove the back housing and reattach to the AIR labeled front .
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
That's what guys have been doing - using any of the rocker type switches from 69-72 vehicles and retrofitting pieces and parts.
Some of those are just momentary activated - so depends on the part(s) you need. Some have just used an incorrect labeled switch as-is. Someone , or two, removed the labeling with solvent or painted over it, aka generic. Yours 'might' be repairable with what you have, with deep ingenuity |
These switches are incredibly crude and the broken black plastic part just holds the contacts while the outer rocker "rocks" back and forth. I may be able to create a whole new base with epoxy but it will be tricky. This needs more thought... |
I have done similar to fan switches on cars that the replacement fan switch is no longer available for. As you say, it just needs to hold the contacts in place. You can likely form a repair or swap in a new board from another switch.
