#1321
Old 09-05-2015, 08:52 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Originally Posted by j69shep View Post
George is a genius. I just did the water pump mod and my 71 455 lemans runs 20 degrees cooler. Thanks George!
What are your before/after temps?
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
  #1322
Old 09-06-2015, 11:10 AM
j69shep j69shep is offline
Highway temp in az after about 10 mile was about 210 now its running 190 on a 95 degree day. Easy fix, 5 bucks in new gaskets and about 90 minutes of work.
The Following User Says Thank You to j69shep For This Useful Post:
  #1323
Old 09-06-2015, 12:30 PM
george kujanski's Avatar
Yes i am a genius and you owe me a buck.
Good to hear another success story, especially in AZ.
George
  #1324
Old 09-06-2015, 02:24 PM
I'd send you a buck via PayPal but you'd end up with 20 cents after the fees kick in so I'm offering one free radio repair. There's a lot of useful info on this site but your cooling fix is tops. Thanks!
  #1325
Old 06-28-2016, 09:42 PM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Awesome , I know its an old post but very good info here!
The Following User Says Thank You to redhawk44 For This Useful Post:
  #1326
Old 09-02-2016, 09:54 PM
MUSLCAH MUSLCAH is offline
I just removed my pump today ...and saw the large gap ,between the impeller and plate.I beat the plate and got it as close without hitting the impeller on my 67 GTO . Put it all back together and drove it home...got stuck at some traffic lights and temp went up to 215...and it was cool at 7:30 tonight. The car has factory AC that works ..but..I can't use it due to hot engine temps.Have the 19" 7 blade fan with shroud and all baffles are there too...new 180 thermostat...spring inside lower rad hose....new Hayden Super Duty clutch too...My next move is to install a new Autometer liquid filled temp gauge ...to get an accurate temp reading. Then if no luck.....what are you guys running for a rad ?..I have the orig 4 core Harrison... Do I go Alu ( what brand ?)... Or the Copper dessert cooler ???? Thanks
The Following User Says Thank You to MUSLCAH For This Useful Post:
  #1327
Old 09-02-2016, 10:51 PM
silverbullet07 silverbullet07 is offline
I would get a hand held thermal thermometer and check the temperture of the thermostat housing when it heats up. Check the temperture differerece between the top and bottom hoses to see what the temp difference is. 215 setting with cast iron heads and engine is not that unnormal. The dummy light does not come on until somewhere around 240.
The Following User Says Thank You to silverbullet07 For This Useful Post:
  #1328
Old 09-03-2016, 11:30 AM
mviker's Avatar
mviker mviker is offline
I'd also suggest ensuring your timing is set correctly. You might need to advance it if you're not running a stock cam. Maybe even if you ARE running a stock cam. I went through a lot of temp issues similar to you. Tried all the ricks, but once I got the timing happy, temps dropped down into a very acceptable range. Someone told me a while back that our Pontiacs like more advanced timing. I can see that now. Just something worth looking into.
The Following User Says Thank You to mviker For This Useful Post:
  #1329
Old 09-03-2016, 12:59 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
A digital infared thermometer is a great tool to have on hand for this sort of thing. My factory gauge shows 220 but my digital thermometer shows 190 at the thermostat housing. There are millions of them available on eBay or Amazon for not a lot of money;
https://www.amazon.com/Nubee-Non-con...ed+thermometer
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following User Says Thank You to pontiacstogo For This Useful Post:
  #1330
Old 03-10-2017, 02:34 PM
GT182's Avatar
GT182 GT182 is offline
This is from the GTO Tech forum....
Originally Posted by 67Twistytee View Post
I ordered a Cardone from Rockauto Gary and it came with a stamped impellar. I sent it back and picked up a Gates 43122 and it came with a perfect cast impellar. I painted it Pontiac blue and reinstalled with my original divider plates. No RTV just the paper gasket and it sits flush with no leaks. Very happy with it.
We now have a part number from Gates and you can see that Andy posted for me. Forget Cardone as they haven't even bothered to let me know the correct part number I've been looking for for a couple of years.
Remember.... Gates 43122.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #1331
Old 03-27-2017, 11:18 AM
Without having to go through the last 10 or 20 pages...Is that the accepted 8-bolt water pump Gary? https://www.amazon.com/Gates-43122-W.../dp/B000C2Y0L6
Old 03-27-2017, 12:38 PM
Old Goat 67's Avatar
Can't tell without a TRUE picture of the impeller.
STILL a crap shoot.
  #1333
Old 03-27-2017, 12:44 PM
This link shows the cast impeller http://www.autopartswarehouse.com/sk.../GAT43122.html
  #1334
Old 03-27-2017, 02:57 PM
67Twistytee's Avatar
67Twistytee 67Twistytee is offline
It is cast implellar and I believe I actually ordered it from Amazon. I consistently run at thermostat temp (180) unless sitting at a long traffic light and then it creeps up to 190. I've made a lot of changes to the engine and cooling system, but I still run original divider plates with the Gates pump, my original a/c Harrison radiator with a re-core, and the 19 inch clutch fan with a Hayden HD clutch. I'll look though my photo file on my laptop and post here if I can locate the shot of the pump impeller.
Andy
North Carolina
1967 GTO SG over Parchment / mom original owner / sold in '78 / found 35 years later
  #1335
Old 03-27-2017, 04:20 PM
Charles, that's what I was wondering about....the cast impeller. I have one here but the bearing is a little rough.
Any of you guys know if the shaft is the same between the cast and stamped impellers? Maybe I could pull the old one and press it onto the new one if it comes stamped?
Old 03-27-2017, 04:21 PM
It is cast impellar and I believe I actually ordered it from Amazon.
Well, that's promising.
Old 03-27-2017, 04:22 PM
That too is promising. Thanks for the link.
Old 03-28-2017, 12:48 PM
Got one of the Gates 43122 pumps through Amazon. We'll see what it is when it gets here.
Old 03-28-2017, 08:05 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is online now
Pics of Gates 43122. Purchased from Rock Auto $39.70 + shipping. Cast impeller, eight bolt. Appears a solid unit but as most everything an offshore item. While test fitting I did notice that the casting where the holes are is a bit thicker than stock and the nuts that go on the studs only go to the top of the studs; on the OEM a few threads stick out so the slotted nuts provide some grip. Shouldn't be a a problem with a dab of Loctite.
ID:	450905   Click image for larger version
ID:	450906   Click image for larger version
ID:	450907   Click image for larger version
  #1340
Old 03-28-2017, 08:20 PM
the cast impeller on the Gates 43122 has full length very aggressive vanes, unlike what was used on a late '63 & '64 8 bolt waterpump. One needs to understand, the '64 radiator has both the rad inlet & outlet on the same side (pass side) of each tank. One can actually circulate the coolant through the radiator too quickly, that's why early 8 bolt pumps used a shorter less agresive vane impeller, than the impellers used in the 8 bolt pumps used from '65-68.
Thread Tools
Display Modes
