Old 07-28-2020, 04:19 PM
66pontiacgto 66pontiacgto is offline
Default 1980 tach
I just bought a 1980 trans am . all the gauges work except tach. tach wires seem to be hooked up. is there something else I should look for or start looking for a new tach.
Old 07-28-2020, 04:48 PM
77 Canamman's Avatar
If the wiring checks out, the most likely culprit is the tach.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 08-29-2020, 05:39 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
The 1980 and 1981 Trans Ams used a different circuit board that prior year 1970s Trans Ams did.
The tachometer board goes bad over time which is not something that can be repaired.
The cure is to replace the circuit board. The meter movement (the part that the white pointer is attached to & that moves the pointer) may also have gone bad from age & use but most often, on those tachs it's the board.
Peter Serio
Owner, Precision Pontiac
