Old 08-05-2020, 06:25 PM
Two_70_Converts Two_70_Converts is offline
Default Repro or Factory?
70 Judge Wing, repro or factory? I seem to recall the early ones had hollow pedestals but not sure.
Old 08-06-2020, 09:14 PM
Joe's Garage Joe's Garage is offline
Default That looks just like the original I took off my 1970 Judge back in 1981.
I remember the originals having hollow legs and being fairly light.
Then the later ones - maybe both factory and repro - had solid legs or more solid legs and were quite a bit heavier.
Also the REALLY early wings from mid-1969 (for 1970 models) had different 'width' spacing for the studs as the legs were further apart.
Your spoiler looks to be factory. The visible seams and the legs look right.
Old 08-08-2020, 07:20 AM
Jason67's Avatar
Jason67 Jason67 is offline
Spoiler differences: http://forums.maxperformanceinc.com/...d.php?t=454438
Jason
Old 08-08-2020, 02:45 PM
marxjunk marxjunk is offline
weigh it..there the proof..28ish pounds is real usually...studs in the pedistal is a good sign too
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 08-08-2020, 05:14 PM
My late October built, Oshawa Judge has a light weight wing; solid pedestals with studs. Three weep holes; one in the middle and one on each end beyond the respective pedestal.
Pedestals set wide as this pic from link
Old 08-10-2020, 09:20 PM
Thanks all for the responses. good info and I don't want to misrepresent it if I sell it. This has the center weep hole but weighs in around 22lbs, not 28. The pedestals are about 10.5 " in from the edge (not exact).
Old 08-13-2020, 10:22 PM
i may have mis stated it...but i sold 3 this year and i really thought they where 28ish lbs..i will look..i posted one here with the weight..
Mark..
The Goat whisperer
