HELP please identifying engine parts.
These parts came from the 400 Pontiac engine in my 77 Trans am. The engine was refurbished and these parts came back in a small box. Can anyone please identify them for me. Thanks
The first pics are timing cover to water pump sleeves. They sit in the timing cover and seal against the impeller divider spacer. Next is fuel pump eccentric bolts up to top timing gear.
water pump /timing cover to block sleeves .....
definately an issue if left out and the fuel pump .. end of cam eccentric .... |
I got treed ..........
Thanks guys so much. That takes a load off my mind.
Pics 3 and 4 might be a hardened valve seat.
Steve F. |
Those are the pieces that go on the water pump sleeves, or on the outside of the cam eccentric.
I don't think they're part of the sleeves. The sleeves shown are complete with the shell and rubber grommets in them.
Steve F. |
Look a bit like a valve spring oil umbrella. Or is that the outside of the eccentric? looks a little small to be that.
68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
Pics 3 and 4 look like an exhaust gasket from manifold to head pipe. What material is it, graphite type material or steel?
3 and 4 are the same thing it goes around the outside of 5
Looks like a us quarter, before the great coin shortage you would se many of these relics.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
Agreed!!!! That's the slip ring. I see it now
Thread Tools | |
Display Modes | |
