Old 09-16-2020, 01:07 PM
goatman73 goatman73 is offline
Default 70 gto PHS axle question
just got back the pHs on a 70 gto i bought and was wondering what special order axle number 362 on order list means? its a 323 ratio car as it has air and thats whats circled on phs,it has a 323 posi in it now and correct build date rear but cant make out 2 letter code,if the phs doesnt list posi then that means it was orig open is that correct?could that be part of the special order axle? thanks.
Old 09-16-2020, 08:08 PM
PontiacJim1959 PontiacJim1959 is offline
Assume your car is a 400CI 4 Bbl, 330 HP, automatic? The specs for your car when you ordered A/C, came factory equipped with 3.08 gearing. So having the 3.23 gear on your car would be special order.
However, the 350HP 400CI shows 3.23 as standard gearing with A/C.
Hope that helps.
Old 09-17-2020, 12:28 AM
its the 350 hp 400,if 323 is standard wonder why the special order on build sheet?it was only like 2.30 for it. thanks.
Old 09-17-2020, 03:48 AM
Kenth's Avatar
Kenth Kenth is offline
PHS would show 361 (G80) if Safe-T-Track was ordered.
Your car may have been ordered with 3.08 gears, thus the 362, and previous owner was not aware of this and had 3.23 gears installed?
Only the PO, stamped code on axle tube or the original build sheet column 29 will tell the truth.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-17-2020, 02:17 PM
k thanks for the info,any thing is possiable.
Thread Tools
Display Modes
