Old 09-21-2020, 11:22 AM
Yellow Bird Yellow Bird is offline
Default WATER PUMP BOLT CONFIGURATION HELP
Can anyone help me with a bolt configuration diagram for my 1977 T/A water pump. I seem to be missing some bolts?
Old 09-23-2020, 10:47 AM
74Grandville 74Grandville is offline
# 1 and #6 should both be the long bolt. make sure you install the lift hook and alternator bracket or the bolts will bottom out.
#3 should be a little longer to go through alternator bracket, but it looks like it's missing
the rest are all the same and I think you're missing a couple.
The other 2 boths you have there look like one is an intake bolt (bolt with 2 threads) and the other may be for the thermostat housing bolt.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 09-23-2020, 08:34 PM
74 Grandville, Thanks for sharing your knowledge, its greatly appreciated. Sometimes this project can get really frustrating.
Old 09-24-2020, 06:19 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I`ve never seen that stud bolt on a water pump. You can see 2 larger holes in the gasket for the longer bolts to pass. They are the top timing cover bolts. One on the alt bracket side and the other for the lift hook. If you don1t have the hook, put a nice thick lock washer there to take the space of the hook.
Never seize on the smaller bolts and don`t over tighten.
Old 09-24-2020, 11:56 AM
This project started in 2004. After several life changes I am again trying to put together my dream car. The engine was returned without the water pump and I never cataloged with diagrams, pictures and text the bolt configuration. These few bolts were contained in a box taped to the engine for almost 20 years. I can't thank you guys enough. Paul AKA Yellow Bird
