Old 09-11-2024, 06:54 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Default 62 compression ratios
Hi all, new to 62 tech, so a quick question on compression ratios.
I see from the 62 manual, there are several different comp ratios for both premium and Std fuel (389 options)
But from what I can see there was only 1x cylinder head listing for this year ?
Am I missing some thing ??? is there an accessory code for different chamber volumes like the later 6X etc ??
From what I could see std engines used 538177 casting and the SD versions used 540306/544127
I couldn't find a different casting for the std engines with different comp ratios ?
Attached is the sheet listing the different ratios from 8.6 to 10.25
I realise these were just advertised ratios, but there is a big difference !!
EDIT----- I think I found it thanks to 61Man !!!!!
" 538177 is the casting number for 1961-62 heads, They have small valves compared to later heads, if they have an X & 0 stamped on the lugs above the center ports they are 10.75/1 with heavy duty valve springs"
Working on going faster (and now staying dry at the same time !!)
Old 09-11-2024, 07:22 PM
Jay S's Avatar
Jay S Jay S is offline
IRC…the low compression 389 had dished pistons
The Following User Says Thank You to Jay S For This Useful Post:
Old 09-11-2024, 08:26 PM
Bill Hanlon's Avatar
Just to muddy the waters, a sheet from the 1966 Pontiac Parts Catalog, showing 1962 engines and what components made them up.
Name:	1962 Pontiac Engines.jpg
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 09-11-2024, 08:37 PM
455-4+1's Avatar
Ahhhhhhhhhh so not quite as simple then.......
Will definitively need to check engine codes ?
Thread Tools
Display Modes
