I know that the last digits of the car's serial number can be found on the engine block and the transmission. I found them on my '77 Trans Am. I also heard that they can be found on the rear end. If that's true, where would it be? I just rebuilt my rear end from scratch, and I don't remember ever seeing any such numbers stamped on there.
No.
No vehicle serial number on the rear axle assembly. There are probably supplier markings, which could include part number/broadcast code, date codes, lot numbers or other internal supplier designations for identification and process flow. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
Agree with Keith. There is a number on the rear but it says what Keith says as well as tells what the ratio is.
The Following User Says Thank You to TAKerry For This Useful Post: | ||
![]() Quote:
rear will usually have a 2 letter code denoting ratio. Lightly stamped so often it disappears with age.
