Old 03-15-2022, 01:24 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Exhaust manifold bolts...
Any alternatives out there....other than used originals or hardware store bolts?
I know I bought new ones from GM about 15 years ago....but not optimistic on current availability..
Old 03-15-2022, 01:44 PM
dataway's Avatar
dataway dataway is offline
If you don't need the various studs included on the OEM bolts then try some place like McMaster-Carr where you can find the exact sizes you need and a choice different strength grades and materials.
Or AMK might sell them very close to original style ... I think there minimum order is $50.
Also our host Ames ... says it has the correct bolt set.
Old 03-15-2022, 02:41 PM
OK thanks.....Had a look at Ames....that theirs are the hardware store style...
I may have found some on ebay...just need to confirm length..
Old 03-15-2022, 03:41 PM
Scott Thelander's Avatar
I have a gallon zip lock almost 1/2 full of decent originals
do you need a couple or a set ?
2o6 465 9l65
they are all loose so I would need to know lengths
Old 03-15-2022, 04:51 PM
dataway's Avatar
^^^^^ Scott was my source for the good OEM originals I used.
Old 03-15-2022, 06:05 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Some of the ones on my 78 where hollow.
Skip Fix
Old 03-15-2022, 07:38 PM
Here is picture of the victim.....
75-78......I believe....3/8" NC x 1 3/4....
And as Skipfix says...some were hollow
