Which diodes go where?
Have my 55 amp alternator disassembled for a rebuild. Removed 3 diodes from the end frame and 3 from the heat sink. After examining all 6 closely I can’t find any indication of which ones are positive and which ones are negative. I will be replacing all the diodes and hope the new ones I buy are marked positive and negative, but still not sure which ones go in the end frame and which ones go in the heat sink. I’m guessing the 3 positive go together in one place and the 3 negative go together in the other place, but which goes where?
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
Diodes.
Probably should have tested them using a multi-meter on the Diode setting before pressing them all out of the heat sink. Make a hand drawn diagram of how all of those go back in.
Peter Serio Owner, Precision Pontiac |
Neg in end frame and pos in heat sink. Usually they are marked red being pos and black being neg. I hope you have all the insulators in order. If you need them I have them and the capacitor with the lock ring
