Old 10-10-2011, 09:21 PM
Stuart's Avatar
Stuart Stuart is offline
The 360hp 428 had 10.5:1 compression and an 067 cam, the 276hp 428HO had 10.75:1 compression and an 068 cam. They both used the same head casting number, so I'm not sure how the compression was raised. The 428HO also had long branch exhaust manifolds
Old 11-21-2011, 03:23 PM
incommunicado incommunicado is offline
Default 67 GP 428 4-speed
Many thanks for the replies. I have begun some work and have started gathering parts. I located a correct block from a fellow PY'er and it is now at the machine shop torn down. The good news is the block and heads are good. The bad is that the crank was cracked. I am now looking for the following:
A rebuildable crank
set of 8 lug wheels (i know there were some differences over the years so I could use some help here.)
full set of door panels, or if someone has experience with the repops I would like to hear from you.
I intend to purchase a set of long branch manifolds, any opinions on what works best, what is closest to factory look? What else I will need or need to know?
Someone here had some cornering lights for a 68 or 69. Are they the same?
Old 11-21-2011, 03:44 PM
67 fullsize cornering lights are similar to 68-69 midsize (A body) but fullsize 68 and 69 corner lamps are completely different from 67 and each other
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 11-21-2011, 10:58 PM
2+2+3x2's Avatar
2+2+3x2 2+2+3x2 is offline
I have a set of cornering lights for you, PM me.
Cary
1967 Grand Prix convertible, 428HO 4 speed
Old 11-22-2011, 03:49 AM
I didn't realize cornering lights were so popular.
http://www.ebay.com/itm/160682030769...84.m1423.l2649
1974 Formula 400 - Ram Air automatic
Old 11-04-2014, 09:58 AM
Default 67 GP Convert 428 4 Speed
3 years in the project and I thought I would share the progress so far. These were taken in late summer 2012.
ID:	380914   Click image for larger version
ID:	380915   Click image for larger version
Old 11-04-2014, 10:04 AM
more pics, at the blast shop, and converting the instrument panel to gauges.
ID:	380917   Click image for larger version
ID:	380918   Click image for larger version
Old 11-04-2014, 10:10 AM
Gauge set restored and rebuilt, the company that restored them had never done this set before and had to create stencils for the face of each gauge.
Body after some blasting and now on a rotisserie, summer of 2014.
ID:	380920   Click image for larger version
ID:	380921   Click image for larger version
Old 11-04-2014, 10:15 AM
Seats are now finished
Correct code 428 now rebuilt to HO specs and ready to install.
ID:	380923   Click image for larger version
ID:	380924   Click image for larger version
Old 11-04-2014, 10:23 AM
The frame, to and from the blast shop, now powder coated.
ID:	380927   Click image for larger version
ID:	380928   Click image for larger version
Old 11-04-2014, 10:29 AM
Beginning to build up the frame summer of 2014. Ram Air tube type front a-arm and rear swing arm kits installed. Note that the rears include frame connectors and a built in heavy sway bar.
8 lugs with 15 X 7 wheels and red lines
ID:	380930   Click image for larger version
ID:	380931   Click image for larger version
Old 11-04-2014, 10:32 AM
428 getting bolt on goodies.
ID:	380933   Click image for larger version
ID:	380934   Click image for larger version
Old 11-04-2014, 10:45 AM
With a little luck the body will be done and in new paint this winter.
The frame is now done, save for some minor touch up. The engine and tranny are all bolted up and it is 99% ready for the body to be installed.
Still need the following to complete:
fan shroud (w/ A/C)
NOS grills (already have the headlight doors)
NOS rt side rocker molding
plastic cover that surrounds the power drivers seat base
4 way power seat switch
8 track player (assuming you could get one with a 4 speed and console?)
battery tray
Old 11-04-2014, 01:56 PM
The "plastic cover that surrounds the power seat base", are you referring to a thin black plastic strip that mounts low on the outboard side of the lwr seat frame. Not sure on a '67 or 68 B series bucket, don't believe they are same as the version used on the '69-72 A-body/GP bucket. Would you have a pic? Know the latter style pwr bucket seat track have shorter height tracks, and it's been extremely rare to find intact pop on plastic "seat track hiders" going back decades. Usually, they are broken. I have pulled strato bucket seats out of 67 Eldorado's several times & don't remember any "track hiders" each time when I changed the pwr seat track out to manual seat tracks.
Btw, really COOL project, looking fwd to more pics
Old 11-05-2014, 11:33 AM
2+2+3x2's Avatar
Love the pics, looks like things are moving along for you, I'm glad, the car looks great. We may have to meet at the drag strip when you are finished! LOL!
Cary
Old 11-05-2014, 06:26 PM
TimeWarp TimeWarp is offline
I believe the plastic around the seat base might be the same in a stratobench car as the stratobucket. Its a shame but I ended up throwing one out about 2 yrs ago when I moved. The whole stratobench power seat in fact. Nobody seemed to want it. Anyway, the stratobench seats were in quite a few GM full size cars of various years, as were the strato buckets. So look at the chevys, Olds, Buicks, etc too. Problem is, nobody knows what they are, so if someone has them listed for sale they'll just call it a 1966 bucket seat from a blah blah blah. My way of searching for things like that is go into ebay, interior parts, seats and do a search for 1965-1970 bucket seats, or bench seats. Takes a lot of time though.
Old 11-07-2014, 10:27 PM
4214speed 4214speed is offline
Where did you get the wheels and trim rings
  #38
Old 11-08-2014, 06:08 AM
compsur's Avatar
compsur compsur is offline
Who restored and rebuilt your Speedo, what was the cost?
1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles
1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles
1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles
1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles
  #39
Old 11-08-2014, 01:01 PM
fan shroud (w/ A/C)
battery tray
When my parents ordered their '67 2+2 they could not get an 8 track with a 4 speed console.
  #40
Old 11-19-2014, 09:03 AM
8 lugs are reconditioned from J&G
Wheels are new 15 X 7 from BOP Engineering
Tires are P235/70R15 BFG Redline
Trim rings are repops from through Ames, not correct style, but a good fit and decent finish
All told drums, new lugnuts, wheels, tires, and trim rings totaled app. $3300.
If anyone wants more details I can get them.
