Old 11-19-2014, 09:09 AM
incommunicado incommunicado is offline
Default 67 GP Convert 428 4 Speed
Originally Posted by compsur View Post
Who restored and rebuilt your Speedo, what was the cost?
I sent the speedo and clock to Auto Instruments in Collinsville, VA. Total for everything was $985, of which almost half was for making the stencils to repaint the individual gauges. They claim that they had never done this set before. FWIW they turned out better than new.
Note, if anyone is considering changing theirs out to gauges, the harness is different and it is a wiring nightmare. Mine is not back in yet, so we shall see how it all works.
  #42
Old 11-19-2014, 03:38 PM
David Jones's Avatar
From the FWIW dept, the 455 I picked up from you (that had lived in this 67 GP) looked brand new inside. I bolted on a set of lightly ported, slightly milled 6X-8 heads, put in a 230-236 hyd roller cam and random other parts from my previous 400. New oil pump, water pump, timing chain etc. It is now living in front of a TKO600 in my GTO.
It is a monster..........
  #43
Old 11-19-2014, 08:34 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
It's not too horrible if you have the wiring diagram\schematics, but they sure didn't make the '67 cluster easy to work on or easy to change out (light bulbs either). It's kind of ridiculous how everything is wired in point to point on these cars...
  #44
Old 11-21-2014, 09:02 AM
Nice to hear from you David and glad the 455 worked out well for you. I sure could have used the oil pan from the motor for the GP, as it is a very shallow pan in the front and no one makes a reproduction that will work, "says he who had the motor in and out 6 times with 3 different pans."
  #45
Old 11-23-2014, 10:20 PM
MCronkGTO MCronkGTO is offline
Was unaware there was a "shallow" front pan. I know there are different pans throughout the years for the different pan gaskets/rear main seals and the drain plug locations. So are you saying an original OEM pan will work but the reproductions won't?
I put new motor mounts in but found out someone had used the wrong tail shaft transmission mount which was taller than the OEM and tilted the motor forward putting the pan closer to the crossmember.
MarkC
ID:	382738   Click image for larger version
  #46
Old 11-25-2014, 09:40 AM
MarkC
Following a lot of research and phone calls, I could not find a reproduction pan that would fit. From what I could tell, the 65-67 used a pan that is shallow and narrow in the front. I have 2 new pans that I would sell cheap!
  #47
Old 12-09-2014, 06:15 PM
gtoric's Avatar
gtoric gtoric is offline
How are you coming on your cornering lights? Do you have the correct turn signal switch for cornering lights? Don't know how hard it is to find this piece.
  #48
Old 12-09-2014, 10:18 PM
perryka's Avatar
perryka perryka is offline
I've seen a couple of them on Ebay lately.
Alan
  #49
Old 12-10-2014, 09:12 AM
Thanks for asking and I found a NOS turn signal switch and I have 2 sets of lights, with one set of bezels out for new chrome now, plus I located a set of NOS lens.
The only thing I don't have is the harness, and I really am not sure what it consists of because I have never looked at one in detail?
I am thinking that worst case I can fabricate one?
If anyone has knowledge, experience, or pictures of the harness it is appreciated.
Looking forward to meeting some of you guys at POCI 2015!
  #50
Old 12-10-2014, 09:34 AM
In 69 the forward lamp harness includes the wiring you need. There is a 1 wire connector that hangs out of the harness.
Btw, the most common reason they don't work at first is bad grounding. They ground to the fender surface so sand the inside of the fender to metal.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
  #51
Old 12-10-2014, 11:26 AM
perryka's Avatar
I bought a new forward lamp harness for my 67 GP with cornering lights, and it had everything needed for those lights. Pretty sure I did not re-use anything from the original harness.
Alan
  #52
Old 02-08-2015, 10:51 AM
Progress report
quarters are now repaired
new trunk pan installed
minor repairs made to floor pans
cowl area around heater core repaired from accident many years ago
I am very fortunate to have a very patient old school body man that agreed to take the project on.
The body and all panels are now very close to being ready for paint.
With a little luck it will be back on the restored chassis by early summer.
ID:	389658   Click image for larger version
ID:	389659   Click image for larger version
  #53
Old 02-14-2015, 07:51 PM
Coach's Avatar
Coach Coach is offline
Thought I would stick my nose in here. Your car is looking fantastic, really makes me miss mine all the more.
-H
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
  #54
Old 02-16-2015, 12:15 PM
Coach, you need to come down and give me a hand. Yours was the inspiration to make me decide to go triple black on this one.
  #55
Old 03-06-2015, 03:37 PM
February was a good month for progress on the GP. Got her paint on yesterday.
Still needs a lot of wetsanding and buffing.
Sorry about the cartoon, I just couldn't help myself.
Name:	Boby w paint 3-6-15.jpg
ID:	392031   Click image for larger version
Name:	Boby w paint #2 3-6-15.jpg
ID:	392032   Click image for larger version
  #56
Old 03-06-2015, 06:46 PM
2+2+3x2's Avatar
2+2+3x2 2+2+3x2 is offline
That's going to be stunning, love the triple black, keep going, there is an end out there.
Cary
1967 Grand Prix convertible, 428HO 4 speed
  #57
Old 04-15-2015, 01:50 PM
Early April update, painted bare body is headed back on the refurbished frame.
Although they are difficult to see, you can pick out the tubular a-arms, rear swing arms and the HD front and rear stabilizer bars.
Name:	GP 4-15-15 #1.jpg
ID:	395496   Click image for larger version
Name:	GP 4-15-15 #2.jpg
  #58
Old 04-16-2015, 04:07 AM
brucee70's Avatar
brucee70 brucee70 is offline
I just bought a tilt column with cornering lamp harness ...I'll take some pics for you and you should be able to make one without too much trouble ...
Bruce
1963 Bonneville SW 421HO
1967 Bonneville SW 400
1969 GP 428 4spd
1970 GTO 400 4spd
1970 Bonneville SW 455
1971 GP 400 4spd
1971 Grandville Conv 455
1972 Catalina Conv 455
1972 Grandville Conv 455
  #59
Old 04-16-2015, 05:17 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Looks great.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #60
Old 02-14-2016, 01:28 PM
Default 67 GP 428 4 speed
Been a while and making some progress. Body and paint are mostly done and assembly is in place. Should have "Argo" back home by June for interior, dash assemble, wiring, fire up the motor for the first time and so on.
what do you guys think about a matching red line stripe?
ID:	420797   Click image for larger version
