Parting out OHC-6 motor
Valve cover $30
Timing cover $30 Oil pan $20 Starter $20 Alternator - don't know if correct but $5 with purchase of another item. Head $30 Distributor, coil, and clear coil wire $10 Crank and caps $50 Exhaust manifold $25 Motor mounts and engine mounts -$20 All items include bolts/screws etc. Come get the whole motor for $100. I can put on a pallet and ship. |
67 OHC
pm sent
67 Lemans OHC 6 Sprint Clone T-5 5 speed convertible |
you still have the motor and engine mounts?
Still have the motor. Motor mounts are sold pending payment.
250 or 230 engine?
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
I assume its an original '67 230. How do you tell?
What are the block cast numbers and block stamped numbers? Can you post pictures?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
I have the motor mounts, I just need the subframe brackets if you still have.
Sold. OHC Sprint 67 has the mounts coming his way. Check to see if he will sell them to you.
Update
Still for sale:
Valve cover $30 Timing cover $30 Oil pan $20 Head $30 Crank and caps $50 239 block #9787437 w/ crank and caps $75 Exhaust manifold $25 More stuff: Engine wiring harness $5 ST300 tranny with torque converter $50 Air cleaner $5 Alternator brackets (both with bolts) $10 Pulleys (both upper and lower) $10 Carburator single barrle $5 All items include bolts/screws etc. Come get the whole motor for $100. I can put on a pallet and ship. |
Thread Tools | |
Display Modes | |
