Looking for a 68 OHC water pump pulley
I'm adding PS to my car .I need a 2 groove water pump pulley part #9778559.
I believe it fits a 68 OHC 250 with power steering . I could also use a 2 groove alternator pulley part # 1968354 . Thanks Don |
Don, When looking for pulleys and PS parts you may want to join the OHC Chapter to help find them unless you already have. I have had success at eBay but sellers tend to type in all sorts of descriptions making it very difficult. The Chapter members might have a spare to sell. The dual groove alternator pulley is going to be very difficult to find. I have looked into having a machine shop grind down some reproduction pulleys that are over-sized. Good luck.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Marc,
Don is a member. He just hasn't shared any images of his car for the FB & Club pages.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Still searching
Thanks for the replies Marc and Jeff . It looks like it is going to be tougher to find than I thought . The water pump pulley should be the same for a 67 & 68.Thanks Don
I have a few alternators with the dual pulley I will check the scrap bin and see if there is a good one I might also have a water pump pulley
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
Thanks for looking
GTOWAGON , I really appreciate you checking on the pulleys . Please let me know if you find anything . Don
ok I have a 2 groove water pump pulley and a 2 groove alternator actually I have several 2 groove alt pulleys shoot me a pm with your address and I will get you a total
Thanks, PM sent , Don
Hi Chris , The pulleys arrived safely . Thank You Don
PS conversion
I did the conversion yesterday . All pulleys , hoses , steering box and pump fit and worked . At the same time I installed the Sprint damper. All in all a good day . Thanks to all that helped make it happen . Don
