Old 12-10-2019, 08:24 PM
cnc's Avatar
cnc cnc is offline
Default Upper control arm bushings
Guys looking for some help here ...but it's on a 73
Apparently sometime in 1973 73's got 74 subframes ...larger 9/16 lower control arm bolts..which is on my car .
The upper control arms on my car could be 73's with bushings the same size OR 74's with two different size bushings ..
Can somebody with a 74 tell me if the bushings are OBVIOUSLY different in size or not....
thanks for any input or pics would be great....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
