Old 02-05-2020, 07:18 PM
Bermudagto's Avatar
Bermudagto Bermudagto is offline
Default 12 Bolt axle ID
I’m trying to Locate the 2 letter stamp on my axle to verify it’s a 3:55. First letters I’ve found are possibly a PR that are stamped overlapping each other. I’m looking for a XV stamp next to a short date code? Gto 455ho no A/c 4-speed.
Old 02-05-2020, 07:27 PM
F ROCK's Avatar
F ROCK F ROCK is offline
pop the cover and read the numbers on the ring gear or count the teeth.
I could never find the codes on my Pontiac rears but my chevy rear it is faintly stamped on the front side of the passenger side axle tube.
the only way to know for sure is to open it up.
Old 02-05-2020, 07:33 PM
Bermudagto's Avatar
Ok. Thanks.
Old 02-05-2020, 08:21 PM
Cking gear dates isnt a sure fire way. Many original 72 12 bolt gear sets aren't stamped with date codes.
Looking at the rear cover view, in the lower RH webbing, in that recess, is there a cast date code?
The assembled factory ID coding should be inboards of the center hsg on the drivers side axle tube facing the back of the car. The XV will be stamped differently than the following assembled date stamp & K (for McKinnon). If needed, can text you examples from several original '70 -72 McKinnon produced 12 bolts to show details. The order of stamped codes changed slightly each year.
Old 02-06-2020, 10:49 AM
Bermudagto's Avatar
I’ll check today. Thank you
Old 02-07-2020, 04:22 PM
Looked at pics of your car, the 12 bolt center hsg appears to be an original McKinnon cast center housing. Earlier I mis spoke on the stamped code location, double cked several out in the shop today.
To see the original stamping look on the front side of the passenger side axle tube, aprox 2 1/2" to the inboard side of the passenger side coil spring mount. the stamped code will end about an 1 1/4 -1 1/2" before the axle tube goes into the center housing.
The coding system used on '72 model McKinnon 12 bolts, should read like the following:
XV K xxxx E
the xxxx represents numbers, which equate to the day of assembly.
the E at the very end of the string signifys the Eaton posi unit.
Old 02-07-2020, 06:12 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=637541
Now I can agree with 'oPh.
So long, farewell.
Old 02-07-2020, 06:32 PM
First page, first picture in that thread shows the casting date of the center housing of a McKinnon cast 12 bolt down on the lower front lip. Occasionally, that casting date is indecipherable due to the last number being replaced by the impression of what looks like a rivet that held the date tag in the mold. Other times, surface rust has attacked that area on the lower lip & the small date code has been obliterated.
The '68, 69, & 70 McKinnobuses embed 12 bolts also have a different way they were coded than later assembled ones.
Old 02-08-2020, 01:59 AM
Bermudagto's Avatar
Default Rear End ID
Located It! Thanks
Old 02-09-2020, 09:18 AM
Looks like they changed it to a Julian date style.
So long, farewell.
Old 02-09-2020, 09:33 AM
yes, for '72 models, McKinnon axle plant had to differ the style of coding from '71 style coding.
Old 02-25-2020, 12:19 PM
Bob Timmermans's Avatar
Bob Timmermans Bob Timmermans is offline
Just get the rear up off the floor and count how many times it takes to turn the driveshaft before a full turn of the wheel.
Old 02-26-2020, 07:41 AM
AG's Avatar
AG AG is offline
Same marking convention as my 1972 XT rear.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 03-05-2020, 09:44 AM
F ROCK's Avatar
Originally Posted by Bermudagto View Post
I’m trying to Locate the 2 letter stamp on my axle to verify it’s a 3:55. .
In his original post he was asking about Gear ratio, not date code.
The only way to know for sure is to count the teeth or read the codes on the gear.
