Cast tripower on Edelbrock heads
Has anyone port matched a stock cast-iron Tripower intake to aftermarket Edelbrock aluminum heads?
Is there enough material in the Pontiac casting to match these up? I am aware of the new KRE manifolds that have enough material, but I have a customer wanting to use a stock cast iron intake on E heads. Thanks. |
FWIW, I opened up a factory cast iron Q-jet intake to match a pair of max-ported E-heads on my 535. The tops of the ports on the intake got very thin. It dynoed with no leakage. If the heads are as cast you should be good.
The Following User Says Thank You to JSuchma For This Useful Post: | ||
Mike -
The alum factory-look-alike manifold I bought from you at Norwalk a few years ago in fact would not cover the E-heads properly (and these are unported heads). The top of the manifold casting and the top of the head port opening were essentially line-on-line. So I bought the Kauffman manifold to solve the problem, and it's SO big I had to mill some of it down in order for the valve covers to fit, but it did the job. Jim C |
Iron intake/ E heads
Thank you for the clarification..
I've used the aftermarket aluminum Tri-Power intake with Edlebrock RAIV heads. We weld aluminum on to the top of the port area, gasket match manifold ports to match the heads. I grind off the nasty looking welds to make it appear as it did before welding. The end result is really good--very good throttle response and fantastic top end from 3,000 rpm to 6,000 rpm. THis was on a 467 and a 428 engine.
I can find pictures if you're interested.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Here are a couple. You can see in both photos how much aluminum was added.
A few more pics.
And more.
Thread Tools | |
Display Modes | |
