Old 04-02-2024, 04:30 PM
77tnt 77tnt is offline
Arrow Parking lamp connector
How does the connector come apart? I don’t want to break it.
Thanks in advance
Old 04-02-2024, 08:44 PM
Cardo's Avatar
Cardo Cardo is offline
Yes it does.
"I know just enough to keep me here, but not enough to get me out"
Old 04-02-2024, 09:59 PM
Wiggle and pull.
Old 04-03-2024, 08:38 AM
Rich-Tripower's Avatar
Be sure to pull on the connectors, NOT the wires.
Old 04-03-2024, 09:30 AM
george kujanski's Avatar
It may have a latch along one edge.
George
Old 04-03-2024, 12:16 PM
bill ryder's Avatar
bill ryder bill ryder is offline
You might also want to run a small bladed screw driver between the black and white plastic in case it is stuck from 60 years of being plugged together.
"Bill"!
Old 04-05-2024, 11:00 AM
Thanks for the helpful responses. I know it seems like a trivial problem but only after 2 hours of wiggling, pulling ,and prying with WD 40 and blaster did I resort to posting here. I am trying to refurbish/restore and reuse as many original parts as possible. I finally did get both right and left side connectors apart by heating the connectors with a heat gun and driving a jewelers flat blade screw driver between the sides of the male and female connectors until the screw driver bottomed on the female connector. Then holding the male end with pliers I tapped on the screw driver handle and it came apart. There was no locking tab and no corrosion in the 3 spades.
