Old 07-16-2023, 11:34 PM
Nyairguard's Avatar
Nyairguard Nyairguard is offline
Default Oil psi gauge feed
im sure this has been discussed here before whats best oil filter housing or plug by distributor ?
Old 07-17-2023, 01:20 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
You can definitely find some threads on this......but rumor has it the plug near the distributor is a more accurate place to get oil PSI.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 07-17-2023, 01:47 AM
wakesupremo wakesupremo is offline
I have 2 gauges (because I was paranoid), using both outlets you describe. Its interesting to note that the filter housing gauge reads slower than the one at the top of the block. This has been discussed on here before and it's because the gauge fitting is on the return line from the filter and I have a remote filter. The filter housing gauge reads slightly higher PSI when the oils hot.
Old 07-17-2023, 08:51 AM
Stuart's Avatar
Stuart Stuart is offline
Assuming you're still also running an idiot light, using the plug by the distributor makes for a neater installation. It avoids having to add a tee fitting at the oil filter housing, which kind of looks messy in my opinion.
The Following User Says Thank You to Stuart For This Useful Post:
