Old 01-20-2020, 07:59 AM
steve25 steve25 is offline
The 455 weighs in at 8 lbs more then the 350 and yet makes a easy 50 more ft lbs of torque in a far more street / strip frendly rpm range even if it's only at 8.2 compression!
If the 455 was a 4 bbl motor then it has better heads then the 350 also.
I gues you know what my pick would be!
Old 01-20-2020, 08:42 AM
sdbob sdbob is offline
455 hands down. Only problem is handling the torque. Clutch,rear, suspension needs reinforced or at least checked for good welds,rust.
Old 01-20-2020, 10:12 AM
David Jones's Avatar
The 73 455 I have in my car had 4X heads and appeared to be as mother GM built it when I got it. I sweated the pilot bushing thing too, since I had already installed a TKO in the car. It turned out the 455 was machined for a pilot.
Old 01-20-2020, 10:49 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
455 all the way!
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 01-20-2020, 10:59 AM
JLuger's Avatar
JLuger JLuger is offline
It looks like it's a factory 4 barrel motor.
Old 01-20-2020, 11:02 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I too needed a bushing fitted on my 455 build. Not a big deal.
Old 01-20-2020, 11:20 AM
1965gp 1965gp is offline
For 1200 I would jump on the 455. Then offer 500 for the 350
Old 01-20-2020, 11:52 AM
73' YC is a factory 4bbl.
Doesn't really matter, but I think you need to check P/N and date code on that intake. It is a factory intake but I don't think it's a 73'. Looks like I see an EGR valve. Don't recall seeing EGR on 'non' CA smog engines. Far as I know the YC wasn't CA smog rated.
IDK
Clay
Old 01-20-2020, 12:08 PM
JLuger's Avatar
Ok gd info picking it up sat.
Old 01-20-2020, 12:17 PM
Sirrotica's Avatar
IDK
Clay
FWIW, 1973 was first year for EGR valves on 49 state engines, I've owned a few of bone stock cars 400s and 455s and they all had EGR systems on them. Plus over the years have worked on many of my customer cars that all 1973 Stratostreak V8s came with EGRs on them.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
JLuger's Avatar
Took a couple of screenshots from video he sent, not sure if you can tell from them.
ID:	529272   Click image for larger version
Old 01-20-2020, 12:20 PM
It looks like a AFB square Bore Carb on a adapter to mate it to the factory Qjet Intake.
That fuel filter sitting right onto of the very hot Exh crossover section of the heads needs to be relocated!
Old 01-20-2020, 12:23 PM
carbking's Avatar
carbking carbking is offline
Originally Posted by ANDYA View Post
A 350 can be made to run pretty strong, BUT I would never put one in a real GTO. For me it would have to be a 389 or larger. I think most GTO enthusiasts would feel the same way.
Real GTO's came with a 350 in 1974.
Jon.
Old 01-20-2020, 12:57 PM
Well if you want to get into detail about the last true GTO was in the A body line, not the relabled Chevy Nova body line .
Old 01-20-2020, 04:42 PM
Will Will is offline
LOL, love these discussions.
But yeah, 455 all day long. Will feel much more powerful due to all the torque it'll make. Cubic inches is what makes torque. Build two engines with the same heads, cam, intake, exhaust, carbs and compression ratios but one is a 350 and one is a 455 and they'll make close to the same Horsepower on a dyno but the 350 will make it at much higher RPM and have less torque overall. The 455 will make a LOT more torque and at lower RPMs.
I have a bone stock '73 455 in my Formula currently. It doesn't want to run out past about 4500 RPMs but it absolutely shreds the tires from a stop or at low speeds. A 350 won't do that.
Old 01-20-2020, 04:44 PM
That makes no sense.
Based on that, the A body GTO was simply a relabeled Chevelle.
Old 01-20-2020, 05:12 PM
JLuger's Avatar
[QUOTE=Will;6102314]LOL, love these discussions.
I have a bone stock '73 455 in my Formula currently. It doesn't want to run out past about 4500 RPMs but it absolutely shreds the tires from a stop or at low speeds. A 350 won't do.
The GTO it's in has 60's out back and he said it just shreds the tires. LOL
  #38
Old 01-20-2020, 06:17 PM
242177P's Avatar
242177P 242177P is offline
That only works if you ignore almost all the A-body sheetmetal.
73+ X cars shared quarter panels, doors, fenders, trunk lids, etc.
Nova
Omega
Ventura
Apollo
  #39
Old 01-20-2020, 08:34 PM
Well, if you'd really rather have the 350, then go for it.
There's a reason Pontiac put 455s in their biggest, heaviest cars rather than 350s. There's a reason why guys who want to go as fast as possible build bigger engines too. If none of that's important, any old engine will do. Heck, you could always put a turbo on that 350.
  #40
Old 01-20-2020, 09:06 PM
After looking at the photos, you can tell it’s not really a Pontiac.
Wrong color.
The Following User Says Thank You to David Jones For This Useful Post:
