Old 01-22-2020, 10:18 PM
footjoy's Avatar
footjoy footjoy is offline
Default Stainless steel valves
On assembled heads can you take a magnet to determine wether your valves are SS. On my heads the magnet sticks to intake valves but not exhaust.
Greg
Old 01-22-2020, 10:33 PM
Steve C. Steve C. is offline
https://www.mtm-inc.com/ac-20110117-...ss-steels.html
Old information here:
Old 01-22-2020, 10:46 PM
footjoy's Avatar
Originally Posted by Steve C. View Post
Thanks so in Laymen terms some SS is magnetic and some isn't?
Greg
Old 01-22-2020, 11:08 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Greg
Yes, all depends on the grade of stainless.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-23-2020, 12:16 AM
The higher the nickel content in the stainless steel, the less the magnetic it is.
Dr. Thomas Sowell
Old 01-23-2020, 08:54 AM
footjoy's Avatar
Thanks to all of you for the information.
Greg
Old 01-26-2020, 07:54 AM
steve25 steve25 is offline
Another consideration when valve shopping is if the valve has a good chrome plating to it or if it has just a ware prone flash chrome plating.
