Old 01-26-2020, 08:38 AM
steve25 steve25 is online now
Default Valve position
Can anyone tell which of these 4 Exh valves where at the rear of this Kaufman high port head?
Old 01-26-2020, 09:11 AM
Half-Inch Stud's Avatar
nope. Valve on the left or right ends of the photo.
Old 01-26-2020, 10:04 AM
Without seeing the head, I'd guess the wet one.
Clay
Old 01-26-2020, 12:03 PM
77 TRASHCAN's Avatar
X2 oil?
Stem seal gave up?
Shut it off
Shut it off
Old 01-27-2020, 07:10 AM
The wet valve was at the end of the head, and the end valve from the other bank looked the same.
Both seal on each valve stem was good and held down to the guide as it should be.
This occurs on most aftermarket Aluminum heads at high rev's when you don't help out the oil drainage at the rear of each head by some means, so this is not only a issue related to only Kaufman heads by any means.
Old 01-27-2020, 10:53 AM
455rebel 455rebel is offline
Because of acceleration G-force?
What's the fix?
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 01-27-2020, 11:22 AM
Stan Weiss's Avatar
Steve,
Is the oil drain back the problem, or is the top end seeing to much oil?
Stan
Pontiac Pump Gas List
Old 01-27-2020, 01:14 PM
Hi gang!
It's a oil drain back problem compounded by a few factors, how much the rear of the motor is tilted which also has the factor of G forces as part of it.
How much unneeded oil that maybe getting out of roller rockers just to mention a few here.
On most of these heads I grind in a drainage trough back forwards to the drain hole and then drill that drain hole out atleast half way down so it can hold more volume and then sometimes a drain port needs to be drilled into the rear of the head with each head bank Y'ed and that line run back to the oil pan.
On some heads the drain trough needs to be ground in right under the Exh valve spring seat cup if no external drain lines can be used.
The condition shown in my picture was not making for a oil usage issue atleast in terms this motors drag strip use, but in terms of running on the street for mile after mile I would have to assume that unneeded oil usage would show up.
