Dumb stroker question
I have a 400 .040 if I put a stoker crank in will I have to change rods and pistons?
I'm guessing You have to . Thanks Greg |
You will have to change pistons to correct pin height. Then, depending on the crank in the kit, maybe rods too.
You usually run BBC rod, 6.7 or 6.8" long. To do it with a Pontiac rod would be out of the norm and cost you more money.
Most kits are with the 6.8 rod. Not sure you can even buy a "stroker" crank with Pontiac rod anymore. |
The Following User Says Thank You to Dragncar For This Useful Post: | ||
I just bought a speedmaster stroker crank that uses the pontiac sized journals last month.
The Eagle 3" main, 4.21 stroke cranks are forged, and cost over $700.
That's why most low buck stroker guys go with the 4.25 stroke cast crank assembly. With the 4.21 stroke crank, you can use stock length Pontiac rods, & Speed Pro L2359NF pistons. The cheaper 4.25 stroker assemblies use Eagle 5140 6.8" rods, & Mahle pistons. https://butlerperformance.com/i-3164...tegory:1459543 |
The Following User Says Thank You to ponyakr For This Useful Post: | ||
It depends on the rod journal diameter of the crank. Some aftermarket cranks have the Pontiac 2.250" rod journal diameter, they can be used with aftermarket Pontiac 6.625" rods. Many forged stroker cranks (like the Scat I used) have BBC 2.200" rod journals, which require BBC rods, most often in 6.7 or 6.8" lengths. Once you know the stroke, the rod length and the block's deck height, you can pick a piston pin height to fit the combination.
The question has got to be......what size journals will it use next month?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
The Following User Says Thank You to David Jones For This Useful Post: | ||
Speedmaster...Woof. |
I take it nobody uses a stock 455 crank that's been ground down to 3" mains anymore?
Nope, because then you're stuck dealing with thrust bearing issues. Why bother when new cranks aren't all that expensive?
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Haven't had to do that in more than 20 years. With all the new cranks offered on the market these days that come in about anything you want it's not worth the effort anymore. |
