Old 04-13-2025, 09:53 AM
jgerardo1983's Avatar
jgerardo1983 jgerardo1983 is offline
Default 1964 389 will a turbo 350 bolt on
I have a 64 Bonneville 389 I paid 4k for the car was going to part the car and keep the engine. Will my 1971 350 transmission bolt to the 389. Is the 389 worth keeping or sell the entire car together ?
Old 04-13-2025, 10:50 AM
tom s tom s is online now
It should,I think all 64 blocks were drilled for the block mounted starter.You will need to confirm yours was.Tom
Old 04-13-2025, 11:54 AM
Thank you. I will take a look
Old 04-13-2025, 03:41 PM
I’ve never seen a 1964 block that wasn’t drilled for a starter.
1964 389 GTO and 326 Tempest engines all had a block mounted starter.
Even the 1964 421 HO that’s in my ‘64 Le Mans convertible has provisions for a block mounted starter even though in a factory big Pontiac installation they didn’t use the block mounted starter.
Old 04-13-2025, 05:52 PM
stevep's Avatar
stevep stevep is offline
Yes
Old 04-15-2025, 12:53 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Same here so far I scored a 64 389 block a while back and it was coded as base engine code Catalina and although it was a slim jim application it was also drilled and tapped just fine, not junk .
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 57k mile
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 86k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 04-15-2025, 10:38 PM
My ‘64 389( 250hp two barrel) is from late February/early March 1964; drilled and tapped for a block mounted starter..
Dr. Thomas Sowell
Old 04-16-2025, 10:26 PM
Unless there is something wrong with the Bonneville trans why not keep it? They were good transmissions unlike the ROTO that was in the Catalina/GP.
