#481
To use the word “coating”, what are we refer to? You can coat the side of the piston, the top, underside, cranks, bearings, valves, heads, ect. The purpose to alter the finish, is what coatings are intended to do. They control friction, oil film, surface metal and heat. The coatings can be made up of many different materials based on the intended use. Many of the materials in property do exactly what they are intended to do. An example of this from my actual experience is hard anodizing applied to a piston. The process allows the piston to resist and dissipate heat faster than an untreated piston. I’ve seen where the chamber in a cylinder head became distorted from heat in which the exact same condition prior to treating the piston became distorted. I’ve also seen where specific coatings that have been used with normal operating conditions, the coating were no longer evident after tear down. So it all depends on the specific application and intended use. In all cases I would prefer coated main, rod and cam bearings in place of non-coated. I would also use specific heat related coatings whenever possible if the budget allows. It increases the latitude of an application and allows other changes in clearances to be used. If these adjustments aren’t taken into consideration during the builds, I can see no attribute to using them, but using the coatings and allowing changes to the build to take advantage of them will only show the value in the process.
Calvin Hill Hill Performance 708-250-7420 |
#482
true enough. I have coated bearings in the engine and elsewhere on the car. I will continue to use them. As a friction modifier....yes. I also agree on hard anodizing pistons in boosted/nitrous applications to help with protecting ring lands etc...
The premise was, coating pistons and combustion chambers = 10-20 hp. Got any reliable info or experience with HP gains that can be measured?
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#483
PY needs coated to protect itself from the BS and so called experts.
The Following 2 Users Say Thank You to slowbird For This Useful Post: | ||
#484
drop cloth?
#485
The Following User Says Thank You to 65nss4spdGTO For This Useful Post: | ||
#486
#487
I hear ya but The way I see it, any change that ALLOWS me to make another change that produces power, then the first changes worth is validated. JMO
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
The Following User Says Thank You to john marcella For This Useful Post: | ||
#488
Damn we have a lot of Ramblers - almost 500 posts -- I feel so proud, like a new daddy
#489
http://youtu.be/PUKMUZ4tlJg Last edited by GTO Dan; 01-17-2014 at 01:27 PM. |
#490
Theoretically, if friction is reduced, heat is reduced, and the reduced friction means there is less internal parasitic losses, which means there is a greater net power at the crank at every RPM. Not even debatable! What IS debatable is if the gain is enough to even measure at the track and conclude that that little difference was a result of the coating, and if so, was it worth the $$$$$.
#491
Ramble on
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#493
I have nothing to contribute, I just wanna be able to say that I posted on "RAMBLERS".
#494
It is debatable....In theory yes it should work, I agree. thats why I investigated it. The question has always been what will the MEASURABLE hp gain likely be? Not that theres no way it could worth anything at all ever. We cannot even get a guy to stand up and say it was measurable on a dyno.....let alone in a track test. To the best of my limited knowledge there are no nascar teams using it OR nhra prostock etc classes. Doesn't the guy who owns diamond pistons,a coating company, and a prostock entry NOT COATING his own teams engine say anything? Any ideas how many thousands of dollars these guys will pay for 20 hp?
#495
Did anyone make that claim? Or have you turned my WAG into a claim? Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#496
LOL, I have been waiting for this post.
#497
Now, do you know Mike Moran?
#498
#499
Yes I do. What words are you going to put in Mike's mouth?
#500
So I'm looking a little closer. FACTS? A guy like you or john should have no trouble finding the real value and applying a calculator for us dummies to "learn from". There are several guys that have supplied me with "tips" on things that can increase HP. They usually sound like this.... "hey mike fyi, i made 13 more hp with xxxx brand and weight oil. Make sure its at xxx temp when you start the pull." You guys have NOTHING? Quote:
Also one would think a much lighter reciprocating weight would show up easy on a dyno, yet most times it does not. It may help shift recovery and accelerate a car slightly faster. Mostly its easier on parts at high rpm.
