Old 01-14-2010, 08:17 PM
Jeff Hamlin's Avatar
Default PONTIAC OHC 6 PARTS
COMPLETE 1966 4BBL INTAKE & EXHAUST MANIFOLDS w/CARBURATOR.
Carb is an AT correct, but would work fine on a MT car.
Carb has been dry for sometime & will need new gaskets.
Included in this package/offer is eveything shown.
$550.00 + shipping. All reasonable offers considered.
Shipping should run around 65-75$ within the 48.
Old 01-14-2010, 08:21 PM
Default More Pics
Parts-
Old 01-14-2010, 08:25 PM
Default Last...
ones.
Old 01-17-2010, 08:20 AM
Default Another 66 4BC IN-Ex man set 4-Sale...
Not as nice but a good usable Matched set for 66-67.
I'm 98% sure, like the above unit these will also bolt-onto the 68-69 250s as well.
$150.00 +ship.
Old 01-20-2010, 07:35 AM
Default LOW mileage Super Turbine ST 300 AT...
Taken out around 89/90k, but has been serviced in the past.
Came out of a 1966 with standard 1BC OHC engine & 3:08 rear.
Ran/shifted great. Trans only no shifter/console parts.
Have the flex plate & pre-bent vacuum modular tubing.
Pick-Up ONLY in Virginia Beach, VA.
$175.00 obo.
I also have some NOS AT parts but are additional cost if interested.
Old 01-23-2010, 09:52 PM
Arrow NOS 68' 250 1bbl cam
NOS 68' 1bbl cam, 12 followers, Cam Housing mounting gasket.
$225+ship
Old 01-24-2010, 07:59 PM
Default CORRECTION...
RE: the cam package.
I stated followers but clearly show adjusters/tappets.
Sorry I don't have any followers to sell.
I also have a real nice cam housing, water neck outlet & by-pass pc.
$95.00+ship
Or a package on all cam related $300.00+ship.
Thanks.
Old 01-25-2010, 07:23 PM
Red face Cam Housing...
Forgot to post the pics,
Old 01-25-2010, 07:45 PM
Default 1966 OHC SPRINT 4BBL AT CARB.
I have this one AT carb left. #7026260.
Listed for use on 1966 230 OHC w/Auto Trans.
However this will mount & work on the 250's as well.
As you can see this has not been used in sometime.
Almost 99% complete and looks to be very original.
Only thing I see missing is the throttle bracket.
It clearly needs to be gone through.
$85.00+ship
Old 01-30-2010, 07:45 AM
Arrow 1bbl In-Ex, Carb set up...
This will bolt on to 66-69 OHC's
Comes with everything but mounting bolts (Man to Head)
$250.00+ship.
Old 02-02-2010, 07:20 AM
Thumbs up 1967 3speed Saginaw manual trans...
Came out of a low mileage 1967 Tempest w/OHC 230 1bbl.
Shifter was long gone This will fit/work on all OHC's 66-69.
$125.00+ship
Old 02-05-2010, 07:01 PM
Gear Ratios on above 3spd are;
2.85
1.68
1.00
2.95
Old 02-09-2010, 06:53 PM
Manifolds in post #4 & Carb in post#9 have been sold.
Poncho,
Payment received. Thank you.
I'll ship parts ASAP
Old 02-11-2010, 08:32 PM
Poncho,
Your PM box is full.
Parts shipped out this afternoon.
Tracking#1ZE229690330961121
LMK if you have any problems & Thanks again.
Old 02-15-2010, 07:23 AM
Arrow REMAN OHC 1bbl Carb
This is a re-man carb & in very good condition.
It is a 67' unit but will fit & function on all 1bc OHC manifolds.
$85.00 +ship
Old 02-19-2010, 07:14 AM
The Intake/Exhaust manifolds from post #4 &
Carb from Post #9 Have been SOLD.
Thanks.
Old 02-22-2010, 07:51 AM
Arrow 66-67 Engine Harness'
I have a few of these on hand. They are still very flexable.
No cut, broken or missing wires/connectors.
Tape is shot. Just clean & re-tape save some $$
They fit & function on both 66-67 A-Body OHC 6 1bbl & 4bbl.
$45.00 shipped.
Old 03-01-2010, 07:14 AM
Arrow RE: Intake & exhaust setup in post #1
Regarding what's included.
Included with this are all mounting gaskets.
Correct oem mounting washers (No bolts)
NOS PCV, Functional heat choke & all linkage.
To be clear this set of manifolds has been cleaned & re-coated.
Ready to be installed.
The Air filter is also GM & correct.
P.S.
If anyone needs parts from the ST300 A.T/ LMK what your after.
This is a low mileage functional trans.
Old 03-05-2010, 07:14 AM
Default ACCESSORY HOUSING W/NOS FUEL PUMP
This came off a fully running engine & was only swapped due to wanting an un-painted housing.
This has new seal, bearing and comes with a re-man Distributor.
Cap, rotor & points are used. I'll add in an NOS fuel pump (66' 4bbl wo/AC)
$125.00 shipped within the 48.
Old 03-10-2010, 07:24 AM
Arrow Pertronix Ignitor for OHC
This is the Pertronix 1126A Ignitor with Optional Flame Thrower Coil.
I'm been using one for years and recommend it to anyone with an OHC.
This one is in full working condition and is already installed on a good Dist;
$125.00 shipped in the 48
(Dist, Cap, Ignitor & Coil)
