Old 12-13-2010, 12:53 PM
ellispj ellispj is offline
Default '64 Upper Control Arm Bumper
I have just recently installed the front control arms and springs on my '64 bare chassis (no body or engine). However, I forgot to install the rubber upper control arm bumpers to the frame. Once the weight of the engine and body are on the frame will I have enough room to get these bumpers in or do I have to uninstall everything and start all over?
Phil
Old 12-13-2010, 04:31 PM
chrisp chrisp is offline
You can sneak them in once the weight is on the frame , jack under control arm 1 side at a time , sneak them in .
Old 12-13-2010, 06:42 PM
Thanks. I was hoping that would be the case.
Phil
Old 12-14-2010, 01:41 AM
andyg's Avatar
andyg andyg is offline
Send a message via AIM to andyg
I did the same thing. I was able to sneak them in, but not able to fully push them into the hole. Once I got them seated enough to stay, I jacked up that side and allowed the control arm to finish pushing them in.
1969 GTO. Full rotisserie restoration "completed" in 2014. 5.3L "LM7", TKO600, 3.55's out back. Big cam coming soon.
Old 12-14-2010, 10:17 AM
shotgun shotgun is offline
PY Staff -Tech
If they are warm , sit in sun or under a lamp, they slide in easier.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 12-14-2010, 03:02 PM
60man's Avatar
60man 60man is offline
NO sweat..I remove & install mine al the time..use them for A arm travel limiters all the time..
ECM member.
MANDRA
Old 12-14-2010, 03:15 PM
Thanks everyone for the replies. I have made a note so that I won't forget to install them.
While we're on this subject, I have been trying to install the rear axle rubber bumpers and there is no way I can get them into the long rectangular slots. The rubber is way too hard. Should I heat them up with a heat gun?
Phil
Old 12-15-2010, 08:45 AM
Grease em up a bit with some silicone spray , use a screwdriver to get edges started in the slot .
Old 08-16-2020, 09:32 AM
RA1John RA1John is offline
Is there a trick to keeping the repro upper control arm bumpers from staying in or not breaking off?
Simply raising/lowering the car on a lift caused one side to tear off at the bumper nib. Cheap repro or are they too tall?
Perhaps apply lube to them so that they slide better on rear side of upper control arm?
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
