Old 08-24-2020, 09:30 AM
racerboy's Avatar
racerboy racerboy is offline
Default 1970 TA shocks with Polyglas tires
If I am planning on running the stock Polyglas bias ply tires, does it make any sense to upgrade to a set of Bilstein shocks? The reason I ask is that I took the car out the other day and it rides kinda rough over bad pavement. I was thinking of upgrading to a better shock but I read somewhere that if you run bias ply tires, you won’t gain much because they are designed to run with radials. I like the stock tires on the JW rims, so if I was going to run radials, I’d have to get another set of wheels. If I can’t run the Bilsteins, what’s the best shock to run with the Polyglas tires?
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 08-24-2020, 09:58 AM
NAPA68 NAPA68 is offline
My 71 has the same set up as you speak of. Having said that, I think it rides and handles alright.
On top of that, I believe the valving of compression to rebound is decidedly different with the original conventional oil shocks. My experience with Corvette's dictates the ride is much better, with a shock that is valved like OE. Outside of buying a set of repo spirals, I do not know where one can buy just an old style oil shock.
I suspect if you comb eBay, you can find some NOS replacement shocks (oil based).
Hope that helps,
Tim
Old 08-24-2020, 12:01 PM
leeklm's Avatar
leeklm leeklm is offline
Back in the 80s when these old cars were my daily drivers, I had a couple that were still running bias ply tires. I would use a run of the mill "Monroe matic" or similar low end gas shock, which seemed to work well on bias or radial tires for a smooth soft ride. Although "soft" may be an overstatement when running bias tires!
Anytime I have moved to a KYB, Bilstien, or other performance shock, the road became more noticeable, which of course is fine if that is what you are looking for, or want something more performance oriented.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 11-28-2020, 08:58 PM
racerboy's Avatar
I finally got around to installing the Bilstiens today, and even with the Polyglas, the car rides 100% better. To be fair, I’m guessing the shocks on it were approaching 10 yr old (but only about 5000 miles). I don’t know if that had anything to do with it, but every time I hit a bump, the whole car seemed to take the hit. The new shocks, while firm, didn’t jar the car and were much smoother over uneven pavement. I took off all the stickers and painted them grey.
Old 12-03-2020, 11:32 PM
bobzdar bobzdar is offline
You could make the switch to the coker Firestone radial wide ovals if you want the bias look in a radial. Not the cheapest but best of both worlds.
The crashes people remember, but drivers remember the near misses.
