Tri-Power Tech 57-66 Tri-Power Talk
Old 05-07-2019, 12:06 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default A piece of art - 66 WV Unit
Most every Muscle Car from the mid 60s and up (that came with Smog equipment) was looked at as a horse power robbing maze under the hood.
These Smog components were commonly removed and tossed in the garbage.
Today, a complete factory unit is a rare site.
The 66 Tri-Power pictured below with all it’s plumbing would have bolted to the top of a WV coded engine of this year.
Complete with full steel fuel lines, secondary Smog air filter and 3 “flame arrester” screens made up this complex unit.
Priceless piece of art.
Chris.
ID:	511736   Click image for larger version
ID:	511737   Click image for larger version
ID:	511738   Click image for larger version
ID:	511739   Click image for larger version
Old 05-07-2019, 08:19 AM
Tom Vaught's Avatar
Boost Engineer
I was not aware that Pontiac used STEEL Fuel Lines on the Tri-Power Carbs in any production application, (even California), learn something new every day.
I thought all the fuel lines to the carbs were always brass fittings and aluminum lines.
Tom V.
Old 05-07-2019, 11:53 PM
John V. John V. is offline
I've always said that the vacuum secondaries were an "elegant' design solution for the day. Given my troubles setting mine up, it is challenging my view but not yet soured me on it.
Same can be said for the '66 Cal smog setup (even the Jan '64 thru '65 Tripower Calif closed crankcase vent system adds interest for me).
I love seeing these unusual details and agree, early smog equipment was not all that reliable and often blamed for poor driveability (often with good reason) so commonly removed (or at least, defeated) to fix engine performance complaints.
Seeing the rare '66 Calif system is art worthy for sure.
Old 05-10-2019, 08:56 PM
60sstuff's Avatar
Default Separate Air Cleaner for the 3x2
The unique “one year only” separate air cleaner for the 66 3x2 Smog GTO.
The filter (A224C) inside the air cleaner is a simple sandwich design. A thick oiled foam envelope wrapped around a heavy perforated steel support which slides between the in and out tubes.
You can see the dirty inside half with cap removed. Another air cleaner shows this steel support without the foam.
This “oiled foam filter” was of the same design as the OEM filters used for all the carburetors when new.
Chris.
ID:	511980   Click image for larger version
ID:	511981   Click image for larger version
ID:	511982   Click image for larger version
ID:	511983   Click image for larger version
Old 05-11-2019, 08:03 AM
DANTIP DANTIP is offline
Default WV parts
Chris,
Love your attention to detail, MANY very hard to find parts there! Here's an intact and working system as well as a portion of a "Recall" letter from Pontiac. The original owner believes the "backfire" screens were added when the car was returned for this work. This car too has original steel fuel lines.
Name:	Screen Shot 2019-05-11 at 7.56.36 AM.jpg
ID:	512031   Click image for larger version
Name:	Screen Shot 2019-05-11 at 8.01.24 AM.jpg
