Tri-Power Tech 57-66 Tri-Power Talk
Old 04-25-2021, 05:04 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default EARLY 1965 intake manifolds
About the first 4 months (Aug. ~ Nov. 1964) of the 1965 GTO build, both the Tri-Power and 4 BBL. intakes had a threaded hole located in the flat boss at the front RH side of intake.
A 1/2” square head steel plug was installed at the factory as this threaded hole was not needed for the ‘65 and newer models.
I’m assuming this was an engineering carry over threaded hole that was used in the previous year, 1964 for its heater hose.
Some of the following photos are poor because they were captured from auctions, but as you can see the dates are Early.
ID:	565412   Click image for larger version
ID:	565413   Click image for larger version
ID:	565414   Click image for larger version
ID:	565415   Click image for larger version
Old 04-25-2021, 05:16 PM
60sstuff's Avatar
Early ‘65 4BBL. intakes.
The first intake is my Sept. 15, 1964 showing a new square head plug next to the factory plug.
The other 4BBL. intakes are Aug. 31, 1964 and Nov. 27, 1964.
If someone is attempting to have their Early GTO date code matching to an NCRS type level for shows than this steel plug should be there.
ID:	565417   Click image for larger version
ID:	565418   Click image for larger version
ID:	565419   Click image for larger version
ID:	565420   Click image for larger version
Old 06-27-2021, 02:33 AM
Why in 1964 didn’t they just put the heater hose in the hole that has the plug on the right side of the manifold where it is on the big car ?
Old 06-27-2021, 09:35 AM
Rich-Tripower's Avatar
Rich-Tripower Rich-Tripower is online now
In 64 they did use that hole in the front right of the manifold. The OP is talking about early 65 applications. Not sure why they changed it for 65.
Here's a picture of our 64 using that front right hole.
Old 06-27-2021, 11:58 AM
Dick Boneske's Avatar
I've seen a few of these '65 intakes with the hole for the heater hose nipple. Apparently, engineering made the heater hose routing from the cylinder head late in product design. I simply install a 3/8" NPT pipe plug in that hole. I'm sure some have found an innovative way to utilize it for an added coolant temp sensor or other device.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-28-2021, 09:03 AM
65 421 TODD's Avatar
65 421 TODD 65 421 TODD is offline
Chris, interesting differences some of these cars had. And at the other end of the 1965 calendar, 1966 parts were showing up early. My '65 4bbl intake 9778816, date G135, has the 1966 PCV System with the 90 degree angle PRESSED IN hose fitting, the nylon hose connector, and the molded vent hose. My '65 has '66 093 heads as the original 77 heads were no longer rebuildable, so I went with the service replacement heads per the PONTIAC CRAFTSMAN SERVICE NEWS, No. 6 - December, 1965.
Name:	GTO Engine 6.28.2021.jpg
ID:	568935   Click image for larger version
Name:	GTO 093 Cylinder Head Pontiac Service Bulletin No.6 December 1965 (2).jpg
The Following User Says Thank You to 65 421 TODD For This Useful Post:
