Old 02-12-2024, 09:59 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Default Parking Brake Cable Waaayyyy Too Short - What Am I Missing Here???
Swapped out all the old parking brake cables for new in my 68 Lemans convt. Originally 350/ 2 sp auto, now 455/TH400. Rear diff is still a factory 10 bolt with original drum brakes. New cables are all from Inline Tube.
It's been a few months since I removed the original parking brake, but I'm pretty sure it's routed correctly. Since it's a TH400, the cable is routed through the crossmember. I'm running the cables above the exhaust, and I'm not getting any interference with anything.
However, now that it's all together, it's about 6" too short, and I have the cable adjusted as loose as possible. I can't get anywhere close to running the cable on the factory hook on the top of the crossmember, so I just stuck it in a lower position on the crossmember. I'm also using the hook supplied by Inline Tube, and it's a few inches longer than the original.
The long center cable is 53" long; if I had one that was about 60" long, I'd probably be good.
I could leave the hook in the wrong spot, adjust it and call it good, but it's bugging me that it's not routed correctly.
Any thoughts?
ID:	628485   Click image for larger version
ID:	628486   Click image for larger version
ID:	628487   Click image for larger version
ID:	628488   Click image for larger version
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 02-12-2024, 10:00 PM
bulletpruf's Avatar
Few more pics...
ID:	628490   Click image for larger version
Old 02-12-2024, 11:04 PM
graygator graygator is offline
To me it looks like the 'big hook' shown in the 777.jpg is in the wrong place. Notice how much closer mine is to the driveshaft and notice how much less bend is put into the cable by the hook.
Kent R.
Old 02-12-2024, 11:10 PM
bulletpruf's Avatar
Yes, as I tried to explain below, the hook is absolutely in the wrong place, but I had to put it there so it could reach the cable. Otherwise, it would be several inches too short.
Old 02-12-2024, 11:34 PM
ID67goat's Avatar
ID67goat ID67goat is offline
First thing I see is that the cable should go above the crossmember (near the floorboard) and not through it…at least that is how I remember it…
Old 02-12-2024, 11:41 PM
bulletpruf's Avatar
It actually is supposed to go through the crossmember on TH400 cars, but not on manual trans cars.
Old 02-13-2024, 03:20 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
I seen your post on the Pedal Assembly and wondering how you have that routed, if somehow incorrect it could be cutting you short, hard to tell from your photos the exact symmetry and angle. If the Pedal Assembly cable is correct and it turns out to be the long one maybe contact Inline Tube and inquire about length and application.
To give a idea for the length, location and symmetry.
For reference, a pic of the manual trans configuration.
Frank
ID:	628530   Click image for larger version
ID:	628531   Click image for larger version
ID:	628532   Click image for larger version
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 02-13-2024, 09:10 AM
bulletpruf's Avatar
Thanks for the pictures. That's how mine is routed. I'm going to give Inline Tube a call today.
Scott
Old 02-18-2024, 06:35 PM
bulletpruf's Avatar
Fixed it. I had two problems -- rod was too short and I had put it in the wrong hole....
I used the longer hooked rod that was in the Inline Tube kit and put it in the hole that was closer to the center of the crossmember.
Geometry looks great now.
Thanks for all the input!
Scott
The Following 3 Users Say Thank You to bulletpruf For This Useful Post:
Old 02-20-2024, 02:07 AM
4zpeed's Avatar
Thanks for the feedback, nice to know the Inline Tube kit is legit.
Frank
Old 02-29-2024, 07:07 PM
Cammer-6 Cammer-6 is offline
Would like to pick your brain for a moment
Is your cable thats coming from pedal the same as the ST300?
Many years ago(about 37) I swapped my ST300 in my 67 for a 200-4R.
I moved the crossmember on the frame to same location the TH400 uses
but kept the same ST300 crossmember .
From what I remember the TH400 used a different E brake cable in front.
Does this kit fix all that or just make the old front cable work?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-29-2024, 07:21 PM
bulletpruf's Avatar
Damn good questions.
My car originally had a 350/ST300/2.78 10 bolt. Now it's 455/TH400/3.90 10 bolt. I'm using a TH400 crossmember. I don't recall how well the original cables fit with the TH400, but I removed them a few years ago, so I can't recall.
Looks like the kits that Inline Tube sells have two flavors - manual trans/TH350 or TH400. Your ST300 cables should be the same as the manual trans/TH350, right? I'm guessing the TH400 has a different length on the front cable, and I'm thinking that's what the 200R4 needs, so that might be your fix.
Scott
