Old 09-27-2020, 07:56 PM
max 93 max 93 is offline
Default Brake pedal too high
The brake pedal seems too high on my 68. The brakes work fine it’s just awkward lifting my foot from the gas pedal to the brake. Is there a way to adjust it or am i possibly missing a piece? The car was originally 4 wheel manual drum brakes but I installed a power front disc kit.
Old 09-27-2020, 08:56 PM
OG68 OG68 is offline
Not sure Firebird is the same as the A body but the Brake pedal should have two holes in the arm. Manual brakes use the upper hole, power brakes the lower.
2007 Cadillac SRX
Old 09-27-2020, 09:00 PM
Hikin Mike's Avatar
Pretty sure my 69 is the same as your 68, but yes, there is an adjustment under the dash by the brake pedal. It's a threaded rod. I had to add another inch of threads on my brake booster threaded rod for my car. In my case my knees are fused straight (can't bend) so I had to lower the brake pedal another inch or so so I could safely drive it. Been driving it like that for 3-4 years now.
- Mike
Old 09-27-2020, 09:04 PM
The rod is in the correct hole
Old 09-27-2020, 11:06 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
You need the little bracket that bolts to the brake pedal and depresses the brake switch.
This bracket allows you to then shorten the brake pedal rod lowering the brake pedal.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 09-28-2020, 11:50 AM
After some googling, I found the bracket you are talking about. Looks like there is a rubber bumper that goes in there also. I got them ordered. Hope that fixes it.
Old 09-30-2020, 09:35 AM
Mcronk Mcronk is offline
Just a FYI. The reason for two different holes in brake pedal is to accomodate the different master cylinders used for manual or power brakes. You will notice manual master cylinders mount flush to firewall and horizontal to the ground. Power brake master cylinders mount to a booster and at an angle to the ground. The holes allow the rod to remain at same angle as the master cylinder.
Old 10-10-2020, 05:22 PM
The little bracket fixed it. Should have looked into this years ago. Thanks for the help.
Old 10-24-2020, 06:03 PM
DM3 DM3 is offline
I am having the same issue, can you post a pic or where you got the bracket?
DM3
IG: #67MoparBird (Follow my rebuild)
1967 Firebird 400
Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?'
Old 10-24-2020, 06:15 PM
https://www.heartbeatcitycamaro.com/...GM%23-3917957/
Old 10-24-2020, 11:15 PM
rohrt rohrt is online now
I'm confused how that part lowers the brake pedal?
Old 10-25-2020, 07:58 AM
It bolts onto the pedal and stops it from coming up so high
https://images.app.goo.gl/xoLAafEyiKZrxEHh6
Old 10-25-2020, 03:16 PM
Ah! Got it thanks.
