Old 09-02-2012, 05:17 PM
hpp's Avatar
hpp hpp is offline
You still have a complete or almost complete ZE or ZD coded 66' engine? Maybe interested in a 4-barrel intake,carb,and the radiator. Thanks
Old 09-02-2012, 05:31 PM
hpp's Avatar
hpp hpp is offline
Also if you have a different year engine almost complete I may be interested in that as well.
Old 09-02-2012, 06:39 PM
Jeff Hamlin's Avatar
Still have the '66 ZD parts in POST#4
Also have the complete engine in POST#2- Item#1 is still avail.
Old 09-02-2012, 11:56 PM
tsmith455 tsmith455 is offline
PM Sent.
Thank you,
Tom
Old 09-03-2012, 09:20 AM
Exclamation Item #1 - Post #2
1969 short block with 1968 head & Cam assembly.
This engine has been machined, bored .40 and rebuilt.
Picked up as a spare. I was amazed to find it machined, assembled and clearly never run.
I have since opened it all up and inspected everything and have found everything to be new/rebuilt.
One cylinder did have some build up due to moisture but I have cleaned it all and the engine rotates perfectly.
As it sits I’m asking $450 obo for the short block, head and cam.
I'm working toward final assembly and plan to run this engine on the shop stand.
As I move forward, price may increase based on parts cost need to finish.
Will also consider parting.
If you are interested in this let me know and I will answer any & all questions.
Old 09-03-2012, 09:23 AM
Default Item #1 - Post #2
Bottom end.
First pic shows current stage. All new gaskets have been installed as I move forward.
(Mounts shown in pic are not included.)
Old 09-08-2012, 08:21 AM
Item#6. Alt Bracket/strap have been sold.
Thanks Tom I'll get it right out.
Old 09-09-2012, 08:59 AM
Default 1966-67 A-BODY TEMPEST RADIATOR
Has been re-cored and has factory previsions for AT cooling lines?
ST300 was air cooled on the OHC so not sure it matters. (My 66 has the same lower tank).
Most likely carry-over surplus parts.
This will fit both 66-67 AT/MT Tempest & Lemans.
Don't know if this will fit '68-'69 Tempest.
I can post dimensions if needed.
$250.00/obo +ship.
Old 09-20-2012, 06:04 AM
Cool ALUMMINUM TIMING BELT COVER ASSEMBLY
This is the correct one year only 1966 metal cover set.
Has a few casting blemishes from the factory but NO cracks.
This cover with all the parts needed to bolt on to any of the OHC engines.
Some like to polish these to a high shine.
$150.00 to your door (lower 48)
Old 09-23-2012, 04:14 PM
hpp's Avatar
hpp hpp is offline
$250.00/obo +ship.
Would this work with a TH-350 trans being it has the previsions for A/T trans?
Old 09-24-2012, 06:33 AM
I would think it would be fine.
Just a matter of making/installing fittings/lines.
Old 10-07-2012, 08:37 AM
Arrow NOS Muffler & good used Y pipe...
28 X 5 Sprint Option Muffler used on both ST & AT Tempest & Lemans OHC 6 models.
Included is my last good Y pipe and a repro trumpet/tip.
$225
Old 10-17-2012, 06:07 PM
Item#3 in POST #2 are SOLD.
Thanks.
Old 10-22-2012, 05:49 AM
'66 4BC IN POST #1 HAS BEEN SOLD.
THANKS
Old 10-22-2012, 11:55 AM
pheasant_2 pheasant_2 is offline
Does anyone have a picture of the correct frame mounts for the 1968 sprint firebird OHC 6 that they could email me at swederlj@gmail.com
Thanks Richard
Old 10-22-2012, 07:30 PM
Default FACTORY 4BC FUEL LINE
This came off a '66 Tempest but could be used on the other years.
Decent shape with the 2 retaining clips.
It is exactly like my '66 with AC, however some of the AC cars had solid line (no rubber hose)
$45 shipped (lower 48)
Old 10-28-2012, 08:53 AM
hpp's Avatar
hpp hpp is offline
THANKS
The carb looks great thanks again.
  #38
Old 11-02-2012, 08:20 PM
OIL PAN IN POST #4 HAS BEEN SOLD.
Thanks.
  #39
Old 11-22-2012, 03:19 PM
ST300 inspection Cover in post #14 has been SOLD.
Thanks!
  #40
Old 11-27-2012, 06:45 AM
Item #11-Starter; in Post#9 has been sold.
Thanks.
