#121
Thanks Matt,
Hoping to get some video soon. I will get some video of the TV pressure test so guys can see what i have done and make suggestions either way. Note to anyone considering this in the future. If you want to log through all the gears manually you will have to relocate/modify the metal stop on the shifter at the rearmost location to give you access to first gear. As it was a 3 speed no need for that much throw. Btw, the geometry is off at the carb "j" bracket supplied with the progressive linkage kit for tripowers. I am going to remove it, add some metal, drill a new hole and try again. maybe the Easter Bunny will bring me some luck! Since the original owner had 3.42's the governor springs may be too heavy now and making it shift to soon as well.
It's hard to soar like an eagle, when you're surrounded by turkeys! My wife says she'd llike my car a lot more if it wasn't mine. 64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam. |
#122
Geometry corrected! if you have a tripower you will need to add some to the "j" to get it closer to the radius. I had to weld a half inch piece of steel to the the lower part to get the geometry right. now off to the trans guy to set the wot shift points!
#123
It will be one of the best all around performing 389 Grand Prixs around on the street with the overall gearing you have.
#124
emailed today What is pictured is what comes in the kit. The plate, bolts, dowel pins, pilot-to-crank extension, and I've started sending the flexplate also. The price is $385.00. Bob Bendtsen [QUOTE=Keith Seymore;5131839]I think I payed closer to $200 for my Bendsten starter mount plate a few years back (Dec '08). the holes look slotted in the Bendsten plate ? if they are did it help in starter tooth aligment ? Quote:
the 15.490 should be taken off left side dowell hole is what I found so far has anyone here used Petes Plans ? my vinyl test pattern from his plans need to change some things but it is a start a coupe of questions about this swap? what flex plate do you use ? 1965 and later 166 tooth ? internial or externial balanced ? does the 2004r converter bolt pattern fit flex plate or do you need to slot dril new holes? Thank you Paul
Donate Life 6-7-04 Liver Transplant Recipitant http://www.donatelife.net/ U S A for Organ Donation Thank You |
