Old 02-01-2016, 11:28 PM
justintiime justintiime is offline
Progress today.
before
during
after
  #42
Old 02-05-2016, 08:21 AM
fender wells off
Fenders being repaired
  #43
Old 02-05-2016, 10:10 AM
Engine-Ear's Avatar
Great pics! Thanks for sharing the nitty-gritty!
  #44
Old 02-07-2016, 03:19 PM
goodbye antenna hole
  #45
Old 02-07-2016, 07:43 PM
repaired fender
  #46
Old 02-10-2016, 12:24 AM
Side trim is off
Holes welded up
1/4 panel dents being pulled out
  #47
Old 02-24-2016, 11:22 PM
more progress!
Measuring the sticker thats been on the car since 1965 in case I want to try to get a duplicate
quarter panel work
taillights are out. doesn't look too bad
rockers have had the trim removed and holes filled
  #48
Old 02-25-2016, 06:46 PM
misterp266's Avatar
Nice progress, I like the no trim idea, will probably at least delete the rocker moldings off my '63 Safari.
Thanks for posting lots of pics!
Rob...
" Darksiders Rule "
  #49
Old 02-25-2016, 09:37 PM
ChiliPepperGarage ChiliPepperGarage is offline
Looking like you are making good progress. You are very inspiring and making me anxious to get working on mine! Thanks for posting up your progress.
  #50
Old 02-25-2016, 10:11 PM
quarter panels are done!
  #51
Old 02-26-2016, 10:41 AM
Engine-Ear's Avatar
Nice!
  #52
Old 03-06-2016, 10:55 AM
More updates:
sanded the quarters and put some more guide coat on them. they are pretty much 100% now
Tailgate looks a little crusty but my body guy says "Sonny fix!" lol See that metal strip? I need one. Dont know where to get it.
Found some wheels today. "Ridler" brand. They are chinese, so I will keep an eye on them.
I bought the wheels on the right, for the rear. Love that huge lip! 20x10 in the rear, and 18x8 in the front. $700 for all the wheels, lugnuts, and valve stems.
  #53
Old 03-06-2016, 02:35 PM
If you are running those rims watch the bearings - that size rim, especially if cast, are VERY hard on the small bearings these cars have. Olds full size ran Set 5 and Set 3 (1962-64) and changed to these (Sets 2 and 6) in 1965, and went right back to the bigger bearings in 1966 till 1977.
  #54
Old 03-06-2016, 05:42 PM
pfilean's Avatar
pfilean pfilean is offline
Looks suspiciously like the strip they used to use between the boards in old Chevy truck beds. Any chance a repop of those can be pressed into service?
  #55
Old 03-06-2016, 09:16 PM
Engine-Ear's Avatar
Thumbs up Good eye!
I like that suggestion!
  #56
Old 03-07-2016, 05:37 AM
I like the suggestion on that metal strip, thank you.
As far as the bearings, thanks for that as well. I do have a 4 wheel disc brake kit I'm putting on. It will use the stock rear bearings, but the front bearings are pressed into the rotors. Not exactly sure what size they would be, but I confirmed yesterday they are all still 5 on 5 bolt pattern, so it should be a "big car" set of brakes.
  #57
Old 03-09-2016, 09:34 PM
Pulled it out to work on it
paid some attention to the firewall. Ended up removing the heater box.
Installed a block off plate as I will be running an under dash AC unit
Seam sealer!
Tailgate coming apart...will need some repair
Thats all for now!
  #58
Old 03-10-2016, 09:49 AM
Engine-Ear's Avatar
Nice.
I'm not pressing you on this, justintime, but I would really like to see a separate thread in this subforum on '61/'62-'64 tailgate removal, disassembly and restoration.
Your posts don't show where you are, but I have to guess that you're where heaters aren't needed, eh?
  #59
Old 03-10-2016, 03:29 PM
Originally Posted by Engine-Ear View Post
Nice.
I've asked my body guy to document the tailgate.
I'm in Roanoke, VA and this is not a daily driver. Heat is not necessary, only air conditioning is
  #60
Old 03-11-2016, 05:20 AM
Tailgate rust repaired
