Old 05-04-2019, 08:52 PM
newmexguy newmexguy is offline
Default 1978 LeMans steering column
1978 LeMans Steering Column. Tilt, column shift. Should work through '80. No wiper controls on stalk. $125 plus ship. Located Zip Code 88032.
Old 05-17-2019, 10:45 PM
Pics of column. Hardware to mount - firewall and dash is included and taped to column.
ID:	512430   Click image for larger version
ID:	512431   Click image for larger version
Old 05-24-2019, 09:32 AM
to the top, still have this, does have ignition cylinder key.
Old 11-10-2019, 11:54 AM
to the top '78 Le Mans steering column with wheel and key. 78-80 style without washer on stalk. Will remove wheel for shipping.
Old 12-21-2019, 10:20 AM
TTT. Still available. '78-80 A Body steering column
Old 04-05-2020, 05:19 PM
to the top. Thanks Dave S.
Old 08-27-2020, 08:05 PM
Default 78-80 A/G Body steering column with key
To the Top. Dave S.
Old 10-11-2020, 03:11 PM
A/G steering column.
Old 10-24-2020, 09:05 AM
Le Mans steering column, 78-80. With Key.
Old 11-18-2020, 08:48 AM
TTT. 78-80 steering column. A Body.
Old 11-18-2020, 09:11 PM
iowapub's Avatar
iowapub iowapub is offline
Do you have the lower section for this column?
1978 has a 1 year only splined shaft.
I have a lower shaft for this column if someone ends up buying this column and needs the lower.
The lower end of the shaft will bolt up to all G body cars....
I am not interested in the column....btw
Old 12-14-2020, 08:43 AM
Default Steering Wheel, shift lever, '78 Lemans.
Sold column yesterday to local customer. Still have steering wheel and shift lever. Wheel, $25, Lever w/ pin $20. Was a Tilt column.
ID:	556143   Click image for larger version
ID:	556144   Click image for larger version
Old 01-10-2021, 12:38 PM
Reposting. Did not have lower section, so local sale was refunded. Original price restored. This is a very good original column with tilt and key. Not torn up.
Old 02-09-2021, 09:04 AM
to the top.
Old 02-20-2021, 10:53 AM
Default '78 Le Mans column
Current pics of column.
ID:	561170   Click image for larger version
ID:	561171   Click image for larger version
ID:	561172   Click image for larger version
ID:	561173   Click image for larger version
Old 04-04-2021, 01:34 PM
Default '78 A body steering column
to the top. '78 Le Mans / A body column. Do not have lower section.
Old 05-16-2021, 01:08 PM
To the top.
Dave S
southern NM
Old 07-09-2021, 07:27 AM
to the top
Dave S
Old 10-02-2021, 09:20 AM
to the top.
Dave S
southern new mexico
Old 02-06-2022, 12:36 PM
Default '78 - '80 Pontiac A body steering column
to the top.
Dave S
southern new mexco usa
