Old 03-27-2018, 08:21 PM
Held for Ransom's Avatar
Default 1970 GTO radiator
Does anyone know where I can find a recoreable radiator w/tag? It was marked BL.
Anyone have a picture of the tag?
So long, farewell.
Old 01-03-2021, 03:02 PM
Found one.
So long, farewell.
Old 01-03-2021, 05:59 PM
Well, apparently 1968 used the same radiator code according to the tag info.
So, that begs the next question. Did they use the '68 radiator in early '70, before going back to the 1969's code of BS later in the '70 model year?
So long, farewell.
Old 01-04-2021, 10:21 AM
Kenth's Avatar
Kenth Kenth is offline
According to the build sheet on my october RAIII A/T -70 Judge it was built with the BL radiator.
Also, BL was used for 1968 400 2 bbl HD and 1970 std 455 GTO´s.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-04-2021, 06:42 PM
vertigto's Avatar
vertigto vertigto is offline
Might be able to check the OEM unit I pulled out of my 70 next time I'm at the shop. Replaced with a Cold Case for my application.
Old 01-04-2021, 08:52 PM
I'd appreciate it.
So long, farewell.
