Old 02-07-2024, 06:11 PM
BirdofFire69 BirdofFire69 is offline
Default steering wheel and column
I lowered my steering column to do some work behind the dash . I reinstalled the column , now steering wheel ,and automatic transmission ( park ) will not lock with the key out . What have I done to cause this, and how can I remedy this ?
Old 02-07-2024, 07:45 PM
forgot to add , its a 1969 firebird. turbo 400
Old 02-08-2024, 02:36 PM
bhill86's Avatar
bhill86 bhill86 is offline
I’ve never laid a hand on a first gen but I assume it’s possible the issue is with your backdrive linkage if installed. A rod may have been bent out of wack or if not installed, the collar on your column (think column shifter) may have rotated out of the “park” position. On 2.ne gens, the key should not come out of the collar isn’t in the park position but I’m not sure if that’s the case in a first gen. I’d assume so.
1977 Trans Am 400/4speed (swap)
Brian
Old 02-10-2024, 01:55 PM
Sport69 Sport69 is offline
I would check steering lock control rod that's part way down the steering column, you shouldn't be able to remove the key if it's working right.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
