#41
They aren't making any more of them, and it's unlikely that Dart is going to pop out heavy-duty replacements.
Clean the block, inspect carefully. Might be a simple repair. But, yeah, grab the other engine, too. Might as well have a spare. ...and maybe consider fabricating a modern version of the block reinforcement plates from decades ago. Pontiac Straight-Eight blocks were known to sag in the middle, leading to crank problems when the main saddles got far enough out of alignment. |
#42
Probably repairable, but can you ever have TOO many spares???
Jon
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
#43
#44
It will smoke for a few minutes like crazy, then it will subside. After you fire it up let it warm up, and retest the compression to see if it had any effect, hopefully it will unstick the rings if that is the root problem. Goodluck.............. |
#45
carb problem on '39
I will offer to look at and fix (if possible) your carb for free. Have worked on a good number of old stuff with relatively good success. You can bring it to me in person and we'll look at it together. Hopefully you'll be able to take it back home with you.
PM me if interested and I'll give you my ph.# to call me and my address if you wish to pursue my offer. Frank |
#46
#47
Let me know when you will be in the area again. Frank |
#48
I picked up the other motor Wednesday morning and did a compression test Wednesday evening. The lowest cylinder was number 1 and it had 120psi! The other 7 were between 125 and 130. I now have to do the test on the motor that is in my 50 to determine which car, the 39 0r the 50 gets this hot rod one!
