Help! How can I break into my Firebird's trunk?
I put a new trunk lock cylinder in my '74 Firebird last month. I bought a set for the doors and trunk so they all matched. Today, I went to open the trunk and I think that somehow, the rod came disconnected with the mechanism. The cylinder turns and there's spring pressure against it, but it's not actually doing anything as far as opening the trunk.
What's the best way to get into this thing? Remove the rear seat? Can I even fit through there? (6', 180 lbs.) Any advice will be really helpful.
1974 Firebird Esprit 1953 Buick Special Riviera 1963 Riviera 1963 Thunderbird 1965 Mustang 1965 Skylark Sport Coupe 1965 Dart 170 Wagon 1965 Corvair Monza Convertible |
You won't fit through there.
Other than a locksmith, you could try using a long extension 'thingy' with like a flat screwdriver blade on the end. Hopefully the shaft is not in the latch. Or try to push it out with the extension tip or wedge it in the latch slot. Twist it to open. (have to visualize how the latch is hooked up and works) Or try unscrewing the bolts that hold the latch.
Get a piece of 3/16" long pre made brake line from the local auto parts store, flatten the end in a vise, or with a hammer. Put it through the trunk from the back seat and stick it in the latch, turn it and you're in.
I've also used hose clamps, or duct tape, to attach a flat bladed screwdriver to a long stick to accomplish the same results. Your choice.................. |
Sounds good, well...not really, but thanks for the tips, guys! Why does it have to be the car with the smallest back seat that pulls this stuff?
The Following User Says Thank You to 242177P For This Useful Post: | ||
My body shop went through this when they installed a repo decklid on my GTO. The original decklid had a reproduction lockset that I always had trouble unlocking. I would get a twist with spring-loaded resistance as the lock cylinder rotated with the key but I would have to do this multiple times while I bounced the car to get it to unlock.
They aligned the decklid, installed the lock and shut the decklid only to find it would not re-open. The body shop found the "tang" on the link bar was thinner than the slot in the latch. It was rotating too far just to "take up the slack" and there wasn't enough rotation left to unlock. That particular lock just happened to be an inaccurate reproduction. I was able to purchase a different link bar that was thicker and solved the problem. I also compared the original latch to a reproduction to be sure the slotted nylon insert ( that accepts link bar) fit was the same. In my case, they were able to take out the back seat for access and rotate the link bar
Triple Black 1971 GTO |
Last resort, drill out the lock and use a screw driver. Lock sets are really cheap at Rock Auto.
A long screwdriver would get you pretty close..or rig up something. Good time to put in a power trunk.
With the rear seat out
and a good flashlight you can use long extensions coupled together and remove the 2 or 3 bolts that hold the latch adapter - that bolts inside the trunklid inner framework. This works 100% of the time So to recap - you are removing the upper piece that bolts into the decklid - that the latch assy catches onto. Not the latch assy that bolts into the rear body panel framework. You probably have the same condition that Neighbor had. ==================== if you can locate a screwdriver or whatnot that might fit into the link bar slot from the back side, like others mentioned, that is worth a try too. Sometimes the rod is all the way through the slot or too deep into the slot and there is no chance to work with it. |
Have you tried pushing down on the trunk lid while turning the key?
I did try that...nothing. The trunk opened fine until yesterday, so something changed. I'll probably tear into it tomorrow and I'll let everyone know what was wrong.
Easy fix, guys...and I have nobody to blame but myself. I was able to open the trunk with a old handle-less screwdriver and a pair of vice-grips. When I installed the new lock cylinder, I used the factory-original lock rod, and the new cylinder was not designed to hold that style of rod tightly. So I just cut the aftermarket rod to length and installed it and it works well. It SHOULD hold together now. Thanks for the ideas, the advice, and the laughs.
