Old 07-27-2020, 06:47 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Safari gas tank removal
Need to pull the tank on my 63.....
I think I have everything unbolted.....both front shrouds (upper and lower) are off as well as strap nut.
Have I missed something...or do I just need to give it a whack?
Old 07-27-2020, 06:55 PM
Heybuck's Avatar
Heybuck Heybuck is offline
A couple of years back I had to lower the tank on my '66 Grand Prix. It did not want to drop down with everything removed.
I eventually sort of pried it down a bit with a piece of wood and it sort of peeled away from the floor pan. On top of the tank was a thick bitumen type of insulation matting and the tank had literally stuck itself to the underside of the trunk floor.
Possibly you have the same problem?
Ian
PS, when I dropped the tank out, I did find a very stained and rotten copy of the cars build sheet.
To laugh at men of sense is the privilege of fools.
Old 07-27-2020, 10:18 PM
Safari tanks (61-64) are mounted side saddle.......in the left quarter behind the rear wheel....
Different deal than car....
Old 07-28-2020, 10:02 PM
misterp266's Avatar
The tank in my ‘63 Safari was very hard to break loose. They fit pretty tight. I have a new one to put back in. You can also get a new strap if yours is rotted.
" Darksiders Rule "
Old 08-14-2020, 12:38 AM
Finally go back on the program.....
Stuck a long flat bar....in between tank and inner panel.....gave it a tweek....and it almost fell out...
Now I need to figure out what to do....with 5 gallons....of 27 year old gas....
Old 08-14-2020, 08:54 AM
Stuart's Avatar
Stuart Stuart is offline
Check to see what municipal hazardous waste disposal options are available in your area. Many cities or counties have provisions for disposing of old gasoline at no charge.
