Old 08-13-2020, 12:18 PM
steve25 steve25 is offline
Default Early rocker arm question here!
Ok , what the heck is different about 1959 389 rocker arms other then the oil feed hole that would not allow the usage of 1964 and up rocker arms on a 1959 motor?
Thanks in advance to anyone who can shed some light on this!
Old 08-13-2020, 02:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The valve stem side of the later rocker arm is longer. If you can get good rocker arm geometry and the pushrod rides in the proper location they will interchange.
Go fast, see Elvis!
Old 08-13-2020, 06:55 PM
tom s tom s is offline
64-65-66 are diff from 67 up.I have used 65-66 on early non pushrod oiling with no issues.Never tried 67 and up.Tom
Old 08-13-2020, 07:12 PM
Bill Hanlon's Avatar
http://forums.maxperformanceinc.com/...0&d=1597345013
This picture does not show a '59 rocker arm. '59 rocker arms do not have an oil spurt hole.
Old 08-13-2020, 07:22 PM
694.1 694.1 is offline
Egge Machine implies that '55-60 are different than 61-63 and offer both.
The 55-60 rockers have reduced size push rod oiling to supplement the stud oiling, this would appear to be a pretty novel offering.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 08-13-2020, 07:29 PM
Dick Boneske's Avatar
1964 and earlier rocker arms had no pushrod oil hole. The exception is the 1964 GTO and 421 engines with 9770716 heads. They did have the oil hole for rocker lube through the pushrods. All 1964 and later Pontiac rocker arms did have the oil hole.
I was not aware of a problem using late rocker arms on a pre '65 engine that lubed the rocker arms through the rocker studs. I'm sure it has been done. What would be the issue?
Are the '67 and up rockers different than pre-'67?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-13-2020, 07:31 PM
Yes Dick they are.Also 63 421HO engines got the pushrod oil along with the 61-63 SD heads.Tom
Old 08-14-2020, 04:15 AM
Kenth's Avatar
Kenth Kenth is offline
1967 1:st design w/o guide plates uses the 389 style rockers.
1967 2:nd design w/guide plates uses the 1968 and later (exc. RAIV) rockers .
Itīs all about the valve stem angle.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-14-2020, 05:21 AM
Thanks all!
