69' Hideaway Switch Consensus ...
hi, all ...
car's original switch was, even after deep cleaning, binding in-out really badly so I grabbed one from Ames. theirs looks mostly the same but doesnt have that push button set up to lock shaft into assemble and a third of the time you turn headlight's on whole shaft comes out ... pretty hilarious. anyway .. while I had nose off I rebuilt actuators, put new bushings in .. hoses are good. I sealed seals where they meet actuators but did not tie seal where shaft passes through it .. hope this isnt a deal breaker. seal, bound directly to shaft, seemed really stressed having to move that full distance. after getting nose up there I tried headlight's but got no love ... when I checked hose connection at switch basically switch came apart in my hand. im about to go out there now and yank the thing off dash but was wondering if there's a consensus on repop switches or should I look for a clean OEM? thanks, mike MA Last edited by RAIIIJudge; 10-29-2023 at 11:34 AM. |
My switch drags as well when turning on/off. I took the switch apart, applied some lube to the rubber pc, and it still is no better. I was going to put a 12vdc valve in I found on Amazon for cheap and tap the headlight wire to control the valve but never got around to doing it, but I think it'd be a good fix if you're not worried about "correct"...
Jimmy M 68 GTO |
mis spoke re- lack of button-release on Ames repop switch: its there ... re-assembled switch
realized check valve was on backwards ... they'll open now but won't close back to it .. |
Oops .. didnt have supply line center at switch ..
They flip and flop : ) Onward upward M |
