Old 11-23-2020, 04:39 PM
98 SNAKE EATER 98 SNAKE EATER is offline
Question Ideas for hidden shift light?
Don't really trust the factory tach in my 70 T/A, but don't wanna upgrade to an aftermarket tach since she's pretty much all original
In my other cars I ran hidden shift lights either in the vents or within the cluster itself
In my 98 T/A, I have one stuffed in the mirror vent
(skip to 6::45 mark in this video)
https://www.youtube.com/watch?v=rCCmPcMlZSU
And in my 69 Road Runner, I have an LED strip light around the main cluster (way too bright though)
https://www.youtube.com/watch?v=nLTr1Wyk7uM
Looking for ideas of where to mount one on this car so that it's completely invisible
Old 11-23-2020, 04:51 PM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
Id make the fasten seat belts light glow for shift light then within the dash.
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
Old 11-23-2020, 06:07 PM
Neutronbomb Neutronbomb is offline
I used this rpm switch to light up the BRAKE light on the gauge cluster.
https://www.raptorperformance.com/pa...d-switch-specs
70 GTO. It's plenty bright in daylight to catch it with your peripheral vision.
Old 11-23-2020, 09:19 PM
When it quits pulling... shift..... works for me..
1974 Formula 400 - Ram Air automatic
Old 11-23-2020, 10:01 PM
Thumbs up
I like this idea
My brake light is actually pretty bright even in the day
https://www.youtube.com/watch?v=VwCz3wg81aQ
DId you use a relay and/or diode or just wire it directly to the RPM switch?
Old 11-23-2020, 10:18 PM
Originally Posted by 98 SNAKE EATER View Post
I like this idea
I wired it direct. If I recall correctly, it provides the ground for that circuit (same as the park brake switch and differential pressure switch).
Old 11-23-2020, 10:52 PM
If it's anything like the one I used on my Road Runner, it should have an option to switch from normally closed to normally open circuit
Old 11-24-2020, 09:20 AM
Keith Seymore's Avatar
Mine's in the top of the cluster, near the high beam indicator.
When the "TGate Ajar" light comes on: SHIFT!!
'63 LeMans Convertible
'63 Grand Prix
Old 11-24-2020, 09:27 AM
JUDGE3 JUDGE3 is offline
couldn't figure out why hide the shift light, then saw your Trans Am and videos. wow. perfection. no shift light needed! dig it.
Old 11-30-2020, 05:47 PM
Yeah, I'm trying to keep her looking as original as possible
Any mods whatesoever has to be hidden from view
https://www.youtube.com/watch?v=65EfN5FEA50
Old 11-30-2020, 09:46 PM
NOT A TA NOT A TA is offline
I put mine where the clock was. I know you'd rather have a more stealth look so as an idea, what about just a face for a light instead of seeing the LEDs that looks like the stock clock but lights up?
John Paige
Lab-14.com
Old 11-30-2020, 10:03 PM
firechicken's Avatar
firechicken firechicken is offline
Great idea especially since the clock never works anyway.
