Ok where does this belong
Thinking some sort of courtesy light ???
Send it! It’s going home on a trailer. |
And this one
The second one is the fiber optic line to the ash tray. It’ll plug into the back of the gauges and that bulb just sits in there to feed the fiber optic line.
I thought the first pic is a harness that plugs into the main harness above the gauges and feeds light to the heater controls or heater and radio? |
The second one is the fiber optic line to the ash tray. It’ll plug into the back of the gauges (mine is in the back of my tach) and that bulb just sits in there to feed the fiber optic line. I don’t believe it actually illuminates the tach in addition, just a convenient spot to grab 12v off the circuit board/sheet.
The first photo may be a courtesy lamp harness for use with a tape player. One socket has a longer length towards the passenger side. Shorter length for the driver's side. I have one for my 67 GTO with tape player
Ok !
On the harness socket length is. Longer than other.
Ok !
Where do they plug in ?
Is this for your 68?
68's didn't have under dash courtesy lights. The Map Light under the dash pad was used instead for convertibles. . For other models just run a white wire from the map light to the headlight switch. Terminals are already there and our sponsor has the wire. The dual lights can be installed under the dash if you wish. Plug into the Orange battery power wire and the white wire to the door switches. You'll need the mounting brackets for the sockets too. The harness length is longer on one end since the plug-in location is offset from center. You can see how the fiber optic cable is installed in this drawing.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Ok
It’s a 69 A/C car
More of where the courtesy lights go
